Adobe CS4 Install During Imaging Not Logging In
  • June 9, 2010
  • 4 replies
  • 32 views
stevewood
Forum|alt.badge.img+38
Y'all may recall that I posted to the list a few months ago about Casper not
logging in during imaging time to install CS4. Well, I opened a support
ticket and JAMF was able to determine there was a bug in 10.6 that was
preventing the auto login to happen.
Well, JAMF contacted me yesterday with a workaround as a temporary fix until
7.3 comes out. The attached PKG file can be added to your configurations to
fix the issue. I added it with a priority of 2 just to make sure it ran
high enough up in the process, and it worked like a charm.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
bentoms
Forum|alt.badge.img+35
  • June 9, 2010
Thankyou for sharing this.
Ben Toms
IT Support Analyst GREY Group
The Johnson Building, 77 Hatton Garden, London, EC1N 8JS
T: +44 (0) 20-3037-3819 |
Main: +44 (0) 20 3037 3000 | IT Helpdesk: +44 (0) 20 3037 3883
donmontalvo
Forum|alt.badge.img+36
  • June 9, 2010
Hi Steve,
I asked our Depo guys (the guys who image for us) and they're having to log in manually when imaging 10.6 workstations too. I searched through the archives but didn't see your previous post about this. Just wanted to confirm, does it matter what version of Mac OS X Server or JSS you're running? If not, I'm happy to test and shout back with confirmation that it works with 10.5.8 server and 7.1 JSS.
Thanks,
Don
stevewood
  • June 9, 2010
As far as I've been told, it has nothing to do with server version or JSS
On Wed, Jun 9, 2010 at 11:09 AM, Don Montalvo <donmontalvo at gmail.com> wrote:
version. This is a bug in 10.6. Apple stopped creating a directory path
that Casper relied on to make the auto login hooks for the Adobe Temp user. I did confirm that Apple fixed the issue in the latest Drop In Box DVDs
that come with the i5/i7 MacBook Pro machines, as I didn't have the issue
with those.
JAMF gave me the PKG file that I sent, which simply creates the missing
directory structure as a work around until 7.3 is released.
Steve Wood
Director of IT
donmontalvo
  • June 9, 2010
You rock, as always. :)
