VPP Apps Not Installing
  • January 30, 2017
  • 4 replies
  • 70 views
Mac OS 10.11.6
Casper/JSS version 9.9.6
On my first attempt at setting up automatic installation of VPP apps, I have run into a situation where only some of the apps will install automatically. I have six free VPP apps that I am trying to deploy via the automatic installation process within the Mac App Store Apps settings. Each time only three install on first login.
TextWrangler
Numbers
Pages
The three remaining: Microsoft Remote Desktop, Keynote and xCode do not install unless I un-scope them from within Mac App Store Apps --> Application, then re-scope them.
I have my configurations for all six apps the same. I have tried this with the apps scoped in a Smart Group/All Users or Single Client/All Users. In each instance it is the same apps that will install or not.
Is there a limit as to how many apps I can automatically install with this process?
Is this a known bug?
Cheryl
Best answer by martel
When I run:
sudo jamf removeMdmProfile
sudo jamf manage
That seems to fix it.
  • February 15, 2017
BUMP.
Did you ever find a solution for this? I have a bunch in scope (7) and are set to install but have yet to actually do so.
/randy
  • May 31, 2017
When I run:
sudo jamf manage
  • December 31, 2017
This works for me. Thanks, @martel l!
  • February 1, 2018
If the logged in user is a standard user, they wont be able to run sudo commands. From the Terminal, type in
su <username of user with local admin rights>
Type in the password and it will open a bash shell under that account. Then run the sudo commands above
