Hi All.. We have 802.1x authentication at the login window using AD credentials. We have enable directory auth (using the machine record credentials and then using user AD credentials once they login. We are noticing that the 802.1x pull down menu at the login window to force the user credential WIFI authentication disappears and sometimes re-appears if a restart or logout occurs. we are running 10.11 and 10.12.
Has anyone else experienced this?
