Massive problem after upgrade IOS from 10.3 to IOS 11.1
  • November 14, 2017
  • 0 replies
  • 11 views
Has sombody the same Problem.
On shared iPads the Update from IOS 10.3 FAILs.
All devices are Stuck in Recovery Mode.
Only System Restore bring them back to live.
It only happens on shared iPads 2017 with IOS 10.3.
It does not matter if the update is rolled out via OTA or the Configurator.
