XQuartz missing library
  • December 19, 2019
  • 37 views
Hi all,
Trying to deploy XQuartz to one of my labs because another software my faculty use is dependent on it. I can install it manually just fine, but when I try to deploy (both by converting the given package into a source, and by capturing the installation using a normal snapshot) it comes up with an error that suggests it won't run on the operating system. Still, it runs when I install manually. I took a look at the detailed error message (below) and it looks like it's missing a library. I'm not sure how to get around this? It seems like it could be something that Composer isn't picking up during the installation.
Process: X11.bin [1033] Path: /Applications/Utilities/XQuartz.app/Contents/MacOS/X11 Identifier: org.macosforge.xquartz.X11 Version: ??? Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: X11.bin [1033] User ID: 501 Date/Time: 2019-12-18 16:44:08.049 -0800 OS Version: Mac OS X 10.14.6 (18G2022) Report Version: 12 Anonymous UUID: 843859CD-6DD9-7631-AE03-ABBF1B258364 Time Awake Since Boot: 180 seconds System Integrity Protection: enabled Crashed Thread: 0 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: DYLD, [0x1] Library missing Application Specific Information: dyld: launch, loading dependent libraries Dyld Error Message: Library not loaded: /opt/X11/*/libAppleWM.7.dylib Referenced from: /Applications/Utilities/XQuartz.app/Contents/MacOS/X11.bin Reason: image not found Binary Images: 0x100000000 - 0x1001b5fff +X11.bin (???) <C155122F-0027-361A-8BCA-A94C2A722F5B> /Applications/Utilities/XQuartz.app/Contents/MacOS/X11.bin 0x100238000 - 0x10025bff7 +org.andymatuschak.Sparkle (1.6 git - 1.6) <BE5E3396-7A0B-3C4C-8838-A7765B2B0A44> /Applications/Utilities/XQuartz.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle 0x10cd98000 - 0x10ce0270f dyld (655.1.1) <B3D9DDCB-5AA7-3674-9608-16B5AA4AA494> /usr/lib/dyld 0x7fff351b1000 - 0x7fff351b1fff com.apple.Carbon (158 - 158) <2BA5A7E5-4C93-35BC-96B6-5A5A24F8D602> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff356b3000 - 0x7fff356b3fff com.apple.Cocoa (6.11 - 23) <3CE2E2C2-A4E8-3CC9-919B-DF487D66F59C> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff3599c000 - 0x7fff35a22fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E8E64E6-0E58-375A-97F7-07CB4EE181AC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff38864000 - 0x7fff388f3fff com.apple.framework.IOKit (2.0.2 - 1483.260.4) <8A90F547-86EF-3DFB-92FE-0E2C0376DD84> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff3fbbb000 - 0x7fff3fbcaffb com.apple.opengl (17.7.3 - 17.7.3) <C7F2455B-3F68-3857-8D28-3502E2DC7E99> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff5ef2d000 - 0x7fff5ef38fff libXplugin.1.dylib (47) <2B0C822A-A00F-31CE-ABDC-6777414375AF> /usr/lib/libXplugin.1.dylib Model: iMac19,2, BootROM 1037.60.50.0.0, 4 processors, Intel Core i3, 3.6 GHz, 16 GB, SMC 2.47f2 Graphics: kHW_AMDRadeonPro555XItem, Radeon Pro 555X, spdisplays_pcie_device, 2 GB Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2400 MHz, Micron, 8ATF1G64HZ-2G6E3 Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2400 MHz, Micron, 8ATF1G64HZ-2G6E3 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Oct 23 2019 08:32:36 version 9.137.11.0.32.6.36 FWID 01-671ec60c Bluetooth: Version 6.0.14d3, 3 services, 27 devices, 1 incoming serial ports Network Service: Ethernet, Ethernet, en0 USB Device: USB 3.1 Bus USB Device: FaceTime HD Camera (Built-in) USB Device: Keyboard Hub USB Device: Apple Optical USB Mouse USB Device: Apple Keyboard Thunderbolt Bus: iMac, Apple Inc., 42.1
Any suggestions?
Thanks in advance!
Best answer by sdickson02
False alarm -- I captured on a completely clean computer and got it working!
1 reply
  • December 19, 2019
