Perhaps I'm confused about how configuration profiles are supposed to work, but I guess that's why we have Q&A forums.
I'm pushing a configuration profile to my users to enable "wake for network access." However, unlike other configuration profile items (e.g., hot corners), a user can turn this setting off, and it is not automatically re-enabled until reboot. So if a user turns it off, then puts his computer to sleep, I can't get at it until I can get physical access to the computer.
Is this the expected behavior?
