API - EnableLostMode - Any Successes?
  • November 14, 2017
  • 13 views
Trying to update my scripts to quickly enable lost mode for devices, but can't get it to work. Anyone had any success with this?
1 reply
  • December 14, 2017
I know this is a bit old but I found your post while trying to figure this out myself. I was able to send DeviceLock and EnableLostMode commands to iPads using the info in this thread. I hope you already found your solution or that this helps.
