command line adding ippusb printers
  • December 22, 2019
  • 0 replies
  • 17 views
Hello,
We got some new IPP USB only printers HP Officejet 2600.
Now adding them via GUI is as usual easy go,...
Now adding those printers via terminal commands seems to be a mess.
Does anyone know how to do this correctly ?
ipp2ppd does pop up in processes creating the ppd. This can be scripted.
Now finding the ippusb url (device uri) with the correct uuid is the problem to generate the correct destination.
May someone help here out.
Mike
