Jamf pro 10 - self service notifications
  • November 15, 2017
  • 47 views
ImAMacGuy
Forum|alt.badge.img+23
I went to enable self service notifications in JP10 and it said I needed a push proxy cert. So I clicked the link and added a new certificate.. when it completes it shows the cert was installed in the list, but an " i " says it cannot add new push certificates.
Can I just renew the existing MDM Push cert or do I need to create a new one because of the push proxy?
Best answer by admin13
@jwojda
That’s a normal message.
It’s just letting you know that you’ve got all the possible push certificates that can be added (so, for example, you can't go in and add a second MDM push certificate or a second Push Proxy certificate) and, if you need to add a new push certificate or push proxy certificate instead of renewing an existing one, one of the existing ones will need to be deleted first.
Were Wulff
Jamf Customer Experience
  • November 16, 2017
@jwojda
Were Wulff
ImAMacGuy
  • November 16, 2017
@were.wulff thanks!
so I don't need to update/replace my existing mdm push cert now that I've added the push proxy?
  • November 16, 2017
@jwojda
Correct.
Your push certificate can stay as is unless you're really itching to renew it early. :)
Were Wulff
