Sharing is caring - Self Service Script for tech - Reset FileVault 2 user password.
  • April 5, 2018
  • 30 views
ThijsX
Forum|alt.badge.img+20
Hi There,
In the mind of sharing is caring see below;
In case that a user has changed his password (via NoMAD or sys prefs) that has been synced to your AD environment but the FileVault 2 Disk Encryption password has not changed you can use the script below.
or they simple dont know their password anymore after a good vacation.
In our situation when someone is unable to login with their own password we log in with or support account, log out to login windows with username / password field and then log in with their New / AD password, when logged in the tech launches self service and is loggin in with his tech credentials where the script is available, depends on your organisations needs.
The script below is designed for your helpdesk technicians and you can scope it to them so they can call it in via Self Service.
This also contains GUI pop-ups.
# Loop until valid input is entered or Cancel is pressed.
while :; do
    userName=$(osascript -e 'Tell application "System Events" to display dialog "Hi,
Ensure that you have set a new password for the user via Active Directory.
Please now insert the username of the user" default answer "" with title "Requesting Username" with text buttons {"Submit"} with icon caution' -e 'text returned of result' 2>/dev/null)
    if (( $? ));
        then exit 1; fi  # Abort, if technician pressed Cancel.
        userName=$(echo "$userName" | sed 's/^ *//' | sed 's/ *$//')  # Trim leading and trailing whitespace.
    if [[ -z "$userName" ]]; then
        # The technician left the username blank
        osascript -e 'Tell application "System Events" to display alert "You must enter the username. Please try again" as warning' >/dev/null
        # Continue loop to prompt again.
            # Valid input: exit loop and continue.
            break
done
# Remove user from FileVault 2.
fdesetup remove -user "$userName"
echo "User has been removed from FileVault 2"
sleep 05
# Pass the credentials for the management account that is authorized with FileVault 2
adminName='PUT IN HERE YOUR SUPPORT ACCOUNT'
adminPass="$(osascript -e 'Tell application "System Events" to display dialog "Please enter the password for SUPPORT ACCOUNT" default answer "" with title "Get admin privilliges" with text buttons {"Ok"} default button 1 with hidden answer' -e 'text returned of result')"
# Check if the logged on user is already authorized with FileVault 2
userCheck=`fdesetup list | awk -v usrN="$userName" -F, 'index($0, usrN) {print $1}'`
if [ "${userCheck}" == "${userName}" ]; then
echo "This user is already added to the FileVault 2 list."
osascript -e 'tell app "System Events" to display dialog "This user is already added to the FileVault 2 list." with title "Not able to add user" buttons {"Quit"}'
exit 1
# Check to see if the encryption process is complete
encryptCheck=`fdesetup status`
statusCheck=$(echo "${encryptCheck}" | grep "FileVault is On.")
expectedStatus="FileVault is On."
if [ "${statusCheck}" != "${expectedStatus}" ]; then
echo "The encryption process has not completed, unable to add user at this time."
osascript -e 'tell app "System Events" to display dialog "The encryption process has not completed, unable to add user at this time." with title "Disk is not encrypted" buttons {"Quit"}'
exit 2
# Get the logged in user's password via prompt
echo "Prompting ${userName} for his/her login password."
userPass="$(osascript -e 'Tell application "System Events" to display dialog "Please enter the password for user '${userName}':" default answer "" with title "Enable user '${userName}' for FileVault 2" with text buttons {"Submit"} default button 1 with hidden answer' -e 'text returned of result')"
echo "Adding user to FileVault 2 list."
# Create the plist file:
echo '<?xml version="1.0" encoding="UTF-8"?>
<plist version="1.0">
<dict>
<key>Username</key>
<string>'$adminName'</string>
<key>Password</key>
<string>'$adminPass'</string>
<key>AdditionalUsers</key>
<array>
    <dict>
        <key>Username</key>
        <string>'$userName'</string>
        <key>Password</key>
        <string>'$userPass'</string>
    </dict>
</array>
</dict>
</plist>' > /tmp/fvenable.plist
# Enable FileVault 2 for the logged on user
fdesetup add -inputplist < /tmp/fvenable.plist
# Check if the user is successfully added to the FileVault 2 list
if [ "${userCheck}" != "${userName}" ]; then
echo "Failed to add user to FileVault 2 list."
osascript -e 'tell app "System Events" to display dialog "Failed to add user '${userName}' to FileVault 2 list." with title "Filevault 2 Failed" buttons {"Quit"}'
exit 3
echo "${userName} has been added to the FileVault 2 list."
osascript -e 'tell app "System Events" to display dialog "'${userName}' has been added to the FileVault 2 list. Reboot required" with title "Well done, Bro.." buttons {"Hooray"}'
# Clean up
if [[ -e /tmp/fvenable.plist ]]; then
    srm /tmp/fvenable.plist
# Updating APFS preboot volume to enable all FV2 users to login
diskutil apfs updatepreboot /
# Restarting macOS
osascript -e 'tell app "loginwindow" to «event aevtrrst»'
Get your fruit out of it.
Cheers,
Thijs.
jbutler47
  • April 10, 2018
Talk about perfect timing. Your script is the bee's knees, perfect workaround to an old and odd issue. Nice work!
  • October 4, 2018
Awesome, this is super helpful!
  • October 4, 2018
This morning I used this script to fix an A1708 MacBook Pro running 10.14 Mojave: It would not accept my password at FV2 log-in window.
