Build a Computer Information script for your Help Desk
  • August 29, 2018
  • 80 replies
  • 444 views
talkingmoose
Forum|alt.badge.img+36
Jamf published Build a Computer Information script for your Help Desk on the Jamf Blog this morning. In that post I used the term "module" to refer to a short script snippet that can read a piece of information from a Mac and display that information as part of a dialog shown to the end user.
For example, this gets the computer name:
# Display computer name
runCommand=$( /usr/sbin/scutil --get ComputerName )
computerName="Computer Name: $runCommand"
This Jamf Nation Discussion is for anyone who's needing assistance creating additional modules and/or helping others create modules.
  • August 29, 2018
We have one like that, however it was just for displaying the monitor serial #.
MonitorSerialNumber=$(system_profiler SPDisplaysDataType | awk '/Display Serial Number/{print $NF;exit}')
ImAMacGuy
Forum|alt.badge.img+23
  • August 29, 2018
it would be really helpful to have a prompt for the user to put in a ticket number and the email address to whom they wish to send it to (we have several IT people scattered across the country and don't have a single catchall email address for all of them.
The ticket number would help the tech look up and know what that user was looking for help with.
Otherwise, it looks great! thank you for sharing!
  • August 30, 2018
I have Outlook set as the default mail app but every time I run "Enable Remote Support" mailto: pulls up Mac Mail. Can I call out Outlook? Any website or anything I use that has a mailto: link always opens Outlook. I don't know why this will not.
Also the directory binding shows as NO and connection failed, but my Mac is definitely bound to AD. Do I need modify something?
Other than that, the script works great for me.
  • August 30, 2018
Once upon a time @Andrina wrote something to send emails through built in mail apps.
Here
In the actual script did you update the domain name for your AD?
Line in question
  • August 30, 2018
Yeah, I already had a script that worked that sets Outlook as the default mail app. This specific script is pulling up mail though, any other mailto: link pulls up Outlook.
I did update the domain information. I will test it out again.
spalmer
  • August 30, 2018
@dmitchell Paul Bowden @pbowden from Microsoft has provided a silent PKG installer that sets Outlook as the default email client. It is compatible with Jamf Pro so it can be pushed out via policy. You could probably run this package before generating the Remote Support email. The package is located at https://macadmins.software/tools/.
  • August 30, 2018
@spalmer This is exactly what I used. If I click a mailto: link on a website, it opens the message to send in Outlook. It's only specifically this script here that opens in Mac mail. I don't see anywhere in the script where it calls out Mac mail specifically.
spalmer
  • August 30, 2018
@dmitchell I hadn't read the article yet, but after skimming through, it doesn't look like the Remote Support section of the script is accounting for the fact that scripts run from Self Service are running as root. Since it is running as root the open "mailto:..." command will not know that Outlook is your default email client since that is a per user setting.
@talkingmoose You may want to update the article to run the open "mailto:..." command as the currently logged in Console user. You can copy the code from the postinstall script in the MailToOutlook.pkg which would essentially be:
CONSOLE=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
Then you could use that to call the mailto command as the currently logged in Console user which would hopefully pick up on the correct default email client settings.
sudo -u $CONSOLE /usr/bin/open "mailto:support@talkingmoose.pvt?subject=Computer Information ($serialNumber)&body=$displayInfo"
I haven't actually tested this so report back if it works.
ThijsX
Forum|alt.badge.img+20
  • Employee
  • August 30, 2018
Tried to sort out to check if it is possible to create a warranty section or age of laptop.
Like that warranty left over period is displayed.
hard to fix since there is a recaptcha on it
any thoughts?
  • August 30, 2018
I use the GSX integration to fill in warranty expiration field in the purchasing tab. @txhaflaire
ThijsX
  • Employee
  • August 30, 2018
@djdavetrouble Nice! i would love to use the GSX but the proces to request an GSX account is not that simple.
Need to be certified for repairing stuff etc right?
talkingmoose
  • Community Manager
  • August 30, 2018
@jwojda, without going into some additional detailed scripting, you could remove the part of the mailto link that addresses the message to force end users to enter an address. Then you could also add to the to body or subject:
[ Please add your ticket number here ]
The Help Desk person would probably need to instruct the end user to add that.
talkingmoose
  • Community Manager
  • August 30, 2018
Excellent catch @spalmer!
I'll be sure to add that mailto check. This is the same behavior folks see when opening HTTP links through Self Service and their default browser is something other than Safari.
Update: I've modified and tested the script with the change. Folks testing the mailto behavior, please let me know if it still doesn't work for you with the updated script.
tguyers360
  • September 2, 2018
I wanted to put this on the MacBook instead of Selfservice so when there is no wi-fi connection the end user can provide information to the helpdesk on a phone call. I placed the script in /users/shared then used appify (https://mathiasbynens.be/notes/shell-script-mac-apps) to make an App and placed it in the Applications folder. I then used configurator to the create a package of the the App in Applications folder a the script in /users/shared a Doc item (called tec support with a nifty icon) to make it easy for the end user to find tec spport and the Microsoft silent PKG installer that sets Outlook as the default email client by Paul Bowden @pbowden that @spalmer mentioned above.(https://macadmins.software/tools/) now my end users can provide information over the phone and through remote support. I hope this helps someone :), happy for feedback if you have a better way
  • September 4, 2018
Hey guys, @rderewianko @dmitchell in that line,
where exactly should i add my domain AD?
mark_mahabir
  • September 4, 2018
Change the part after
/Active Directory/
in the following line to match your domain:
runCommand=$( /usr/bin/dscl "/Active Directory/TALKINGMOOSE/All Domains" read /Users )
  • September 4, 2018
@mark.mahabir thank so much for the tip, i actually did that before asking and didn't work, but i was hoping maybe that wasn't the right line, ill try on a different machine.
edit: i ask around and was using a wrong path for the domain, we correct that and we change the line 124 with the right domain address.
All good now, messing around with the other options for team-viewer now.
btw, this is a great exercise, specially for people like me with no great exposure to scripting on jamf(and in general)
thanks guys!
  • September 5, 2018
Another scripting beginner here...
How would I go about removing the 'Enable Remote Support' button altogether, is that possible? I really just want our users to be able to locate their computer name, serial & IP quickly when calling our Service Desk.
  • September 5, 2018
Hi all,
Yet another script newbie here.
With regard to the Hardware section. Our Mac HD's are all named differently with the asset tag, is there a way to use a wild card in place of the "Macintosh HD", so we can get the disk space to display for each different user. I have tried a couple of things without success.
Also would anyone have a way to display no. of days until AD password expiry, that would be a great help to our Helpdesk.
Many thanks
  • September 5, 2018
To answer my own question, I just changed the line:
runCommand="button returned of (display dialog "$displayInfo" with title "Computer Information" with icon file posix file "/System/Library/CoreServices/Finder.app/Contents/Resources/Finder.icns" buttons {"Enable Remote Support", "OK"} default button {"OK"})"
to read:
runCommand="button returned of (display dialog "$displayInfo" with title "Computer Information" with icon file posix file "/System/Library/CoreServices/Finder.app/Contents/Resources/Finder.icns" buttons {"OK"} default button {"OK"})"
Great work and thank you, @talkingmoose
talkingmoose
  • Community Manager
  • September 5, 2018
@ianmb, absolutely the right way to do that. You figured it out.
If you want to further clean up the script, you can remove the lines in the ## Run additional commands ##### section down to the exit 0. Their only purpose is to support that button. Optionally, you can leave them there in case you may want to re-add the button.
talkingmoose
  • Community Manager
  • September 5, 2018
@sdunbar
Edit lines 146-147 and replace "Macintosh HD" with disk1s1 and test. That "device identifier" should generally work unless you've possibly partitioned your drives in some unusual way.
If that doesn't get you want you need, you can run the following command in Terminal on a test machine to find what does work. Replace "Macintosh HD" with the name of the drive on your test machine.
/usr/sbin/diskutil info -all | /usr/bin/grep "Macintosh HD" -B 6
What it's doing
The /usr/sbin/diskutil info -all part of this one-liner lists all the information for all your drives. The /usr/bin/grep "Macintosh HD" -B 6 part of the one-liner takes the results of the first command and returns just the lines that contain "Macintosh HD". Then it counts six lines up (before) from the "Macintosh HD" line and displays those lines too. The first one should be something like Device Identifier: disk1s1.
This one's trickier. From what I've seen, we can read from the end user's AD account when the password was last changed, but we also need to know the domain's password policy. Does it require passwords change every 90 days? Every 180? I've yet to see a simple script that simply returns password expiration. NoMAD does have a feature to do this and will display remaining days in the menu bar. It's open source and free to use if you're willing to rely on the community for support.
Maybe someone else will have a better answer for your question.
  • September 5, 2018
@sdunbar I'm glad you pointed that out about the "Macintosh HD" name being hardcoded. When looking at the script that popped out at me as well. These two lines
FreeSpace=$( /usr/sbin/diskutil info "Macintosh HD" | /usr/bin/grep  -E 'Free Space|Available Space' | /usr/bin/awk -F ":s*" '{ print $2 }' | awk -F "(" '{ print $1 }' | xargs )
FreePercentage=$( /usr/sbin/diskutil info "Macintosh HD" | /usr/bin/grep -E 'Free Space|Available Space' | /usr/bin/awk -F "(\\(|\\))" '{ print $6 }' )
Can actually be simplified to the following, which should work fine since this won't necessarily be run from another booted volume I presume. The / instead of Macintosh HD tells diskutil to look at the boot volume, so essentially the same thing as "Macintosh HD" or whatever the volume is named.
FreeSpace=$( /usr/sbin/diskutil info / | awk -F'[:|(]' '/Free Space|Available Space/{print $2}' | xargs )
FreePercentage=$( /usr/sbin/diskutil info / | awk -F'[(|)]' '/Free Space|Available Space/{print $6}' | xargs )
See if that gets you what you want.
  • September 6, 2018
Many thanks @mm2270 & @talkingmoose
Both of those worked a charm, I think I'll go with the more generic / instead of Macintosh HD as that will be more forgiving with our eclectic naming conventions.
With regard to the AD password expiry, I did find a post on setting it as an Extension Attribute here based on a 90 day policy, but could not successfully get it into the script to display with the rest of the info.
We have looked as Nomad etc before, but I thought it would be nice and easy for the Helpdesk to have it all in just one place.
Again much appreciated for all of the above.
Cheers!
talkingmoose
  • Community Manager
  • September 7, 2018
@sdunbar, that was an excellent script source for days until password expiration. It was fairly easy to make this into something you can add to the full script. I took a little liberty to clean up the code but for the most part used that solution here.
Paste the following snippet somewhere in the body of the script. I suggest around line 140 after the # Test Active Directory binding section. You'll need to modify both the domainName and maximumAge values near the top.
# Display days to AD password expiration
# NetBIOS domain name
domainName="TALKINGMOOSE"
# Maximum password age in days
maximumAge=90
# Get current user
currentUser=$( stat -f "%Su" /dev/console )
# Last password set date
lastPasswordSet=$( dscl "/Active Directory/$domainName/All Domains" read "/Users/$currentUser" SMBPasswordLastSet | awk '{print $2}' )
# Calculations
lastPasswordCalc1=$(( $lastPasswordSet / 10000000 - 1644473600 ))
lastPasswordCalc2=$(( $lastPasswordCalc1 - 10000000000 ))
timeStampToday=$( date +%s )
timeSinceChange=$(( $timeStampToday - $lastPasswordCalc2 ))
daysSinceChange=$(( $timeSinceChange / 86400 ))
daysRemaining="Active Directory password expiration: $(( $maximumAge - $daysSinceChange )) days"
The last variable daysRemaining is what we want to add to displayInfo. I suggest in this section of the script:
ACTIVE DIRECTORY
$AD
$testAD
$daysRemaining
The end result looks like:
