Smart Group for iOS 11 Compatible Devices
  • April 6, 2018
  • 7 replies
  • 107 views
I've just created a smart group for iOS 11 compatible devices that you might find useful
<mobile_device_group>
  <name>iOS 11 Compatible</name>
  <is_smart>true</is_smart>
  <criteria>
    <size>33</size>
    <criterion>
      <name>Model Identifier</name>
      <priority>0</priority>
      <and_or>AND</and_or>
      <search_type>is not</search_type>
      <value>iPad1,1</value>
      <opening_paren>false</opening_paren>
      <closing_paren>false</closing_paren>
    </criterion>
    <criterion>
      <priority>1</priority>
      <and_or>and</and_or>
      <value>iPad2,1</value>
    </criterion>
    <criterion>
      <priority>2</priority>
      <value>iPad2,4</value>
    </criterion>
    <criterion>
      <priority>3</priority>
      <value>iPad2,2</value>
    </criterion>
    <criterion>
      <priority>4</priority>
      <value>iPad2,3</value>
    </criterion>
    <criterion>
      <priority>5</priority>
      <value>iPad3,1</value>
    </criterion>
    <criterion>
      <priority>6</priority>
      <value>iPad3,2</value>
    </criterion>
    <criterion>
      <priority>7</priority>
      <value>iPad3,3</value>
    </criterion>
    <criterion>
      <priority>8</priority>
      <value>iPad3,4</value>
    </criterion>
    <criterion>
      <priority>9</priority>
      <value>iPad3,5</value>
    </criterion>
    <criterion>
      <priority>10</priority>
      <value>iPad3,6</value>
    </criterion>
    <criterion>
      <priority>11</priority>
      <value>iPad2,5</value>
    </criterion>
    <criterion>
      <priority>12</priority>
      <value>iPad2,6</value>
    </criterion>
    <criterion>
      <priority>13</priority>
      <value>iPad2,7</value>
    </criterion>
    <criterion>
      <priority>14</priority>
      <value>AppleTV1,1</value>
    </criterion>
    <criterion>
      <priority>15</priority>
      <value>AppleTV2,1</value>
    </criterion>
    <criterion>
      <priority>16</priority>
      <value>AppleTV3,1</value>
    </criterion>
    <criterion>
      <priority>17</priority>
      <value>iPod1,1</value>
    </criterion>
    <criterion>
      <priority>18</priority>
      <value>iPod2,1</value>
    </criterion>
    <criterion>
      <priority>19</priority>
      <value>iPod3,1</value>
    </criterion>
    <criterion>
      <priority>20</priority>
      <value>iPod4,1</value>
    </criterion>
    <criterion>
      <priority>21</priority>
      <value>iPod5,1</value>
    </criterion>
    <criterion>
      <priority>22</priority>
      <value>iPhone1,1</value>
    </criterion>
    <criterion>
      <priority>23</priority>
      <value>iPhone1,2</value>
    </criterion>
    <criterion>
      <priority>24</priority>
      <value>iPhone2,1</value>
    </criterion>
    <criterion>
      <priority>25</priority>
      <value>iPhone3,1</value>
    </criterion>
    <criterion>
      <priority>26</priority>
      <value>iPhone3,3</value>
    </criterion>
    <criterion>
      <priority>27</priority>
      <value>iPhone4,1</value>
    </criterion>
    <criterion>
      <priority>28</priority>
      <value>iPhone5,1</value>
    </criterion>
    <criterion>
      <priority>29</priority>
      <value>iPhone5,2</value>
    </criterion>
    <criterion>
      <priority>30</priority>
      <value>iPhone5,3</value>
    </criterion>
    <criterion>
      <priority>31</priority>
      <value>iPhone5,4</value>
    </criterion>
    <criterion>
      <priority>32</priority>
      <value>iPhone3,2</value>
    </criterion>
  </criteria>
  <mobile_devices/>
</mobile_device_group>
Save this as an XML file and you can upload it to your JSS with this command. Using id/0 will automatically assign the next available smart group ID after your existing groups in the JSS (Thanks Mike!).
curl -skfu adminuser:adminpassword https://jssURL.com:8443/JSSResource/mobiledevicegroups/id/0 -T /pathtofile.xml  -X POST;
Hope that saves you a bit of time!
Forum|alt.badge.img+22
  • Employee
  • April 6, 2018
Thanks for sharing this. You can and should always POST to /id/0 so that way it just automatically selects the next available JSS ID, no need to try to figure out whats available.
  • April 17, 2018
Top tip, thanks Mike. Wasn't sure how that worked.
DominikFahrin
  • August 31, 2018
Can anyone make this for iOS 12 compatible devices?
Thanks and Greets from Germany
Dominik
  • August 31, 2018
If the device can run iOS 11 it can run iOS 12.
a site that can help.
http://iossupportmatrix.com/
DanielMa
  • Employee
  • August 31, 2018
Nice work @philipwoods one thing i would mention, having a smart group with more than 10 criteria can have an impact on performance when the group re-calculates.
Might I suggest you leverage the regex options in the smart group
such as in the image where you can limit to a number range so in the example if all iPad models 4,x and greater can support iOS 11 you can use ^iPad[4-9,[1-9]:
^iPad means it the beginning of the line matches iPad
[4-9] means any number between and including 4-9
, just the separator that Apple users for Model Identifier
[1-9] second number set that could include 1-9
For more information on regex you can refer to the kb article: https://www.jamf.com/jamf-nation/articles/496/using-regex-with-smart-groups-and-advanced-searches
DominikFahrin
  • September 27, 2019
Hello together,
has anyone a xml for iOS / iPadOS 13?
Greets
Dominik
  • December 16, 2019
If you create a smart group with Model Identifier criteria values matching the following "matches regex" operators with "or" connectors you will have a smart list with any device that can not be upgraded to tvOS/iOS/iPadOS 13.
^iPad[1-4],[1-9]
^AppleTV[1-3],[1-2]
^iPod[1-7],[1-1]
^iPhone[1-7],[1-4]
