I noticed my freshly imaged 10.11.4 computers were hanging on boot when FV was enabled.
To troubleshoot, if I do an erase and install of 10.11.5 and enable FV through system prefs - machine boots normally.
If I do an erase and install of 10.11.5 and run quickadd to get machine talking to JSS and then run our enable FV policy, FV enables fine, but on boot up after I enter the local admin password, the progress bar hangs about 55% of the way through.
If I let it sit there for 15 minutes and it never boots. If I tap the return key, booting happens as normal.
It happens on every boot. I assumed it was a networking issue, so I disabled all network interfaces & same result. Nothing jumps out at me in the system.log, not sure what other logging to look at.
Anyone seen this, or have any ideas? We are using institutional and individual recovery keys.
