I recently started using a 10.6.3 base image and seem to be having an issue with some of the packages that get installed after imaging. I don't recall having the issue before 10.6. Essentially I have a 10.6 image, a bunch of packages (Apps, etc) that get cached and installed, and then after imaging and a computer restart, it hits my "postimage" policy. During this, it installs some packages that have postflight scripts and other such things that need to run in a live OS.
My problem is that I get notification that the policy is failing but I'm not sure what exactly is failing. All of the packages install just fine when I run them from the command line.
I have a couple of questions:
1. What is the "*Missing bundle Identifier" error?
2. Is the Install Wacom Tablet really failing? It's successful when I run the installer -pkg /Path/to/pkg -target /
3. I have a script which sets the softwareupdate server (second block of bold below) based on a 10.5 vs 10.6 install. It exits 0, but then system profiler throws an "Exception while calling"... What's failing there? It seems to run just fine when running the script.
Other than the postimage errors, it all seems to be working quite well!
/usr/sbin/jamf is version 7.2
Executing Policy PostImage: Install Sophos, Mail cert....
Caching package...
Downloading BOM for 10.5.8 Cups Fix.pkg...
Downloading Components of http://JSS.mydomain.com:80/CasperShare/Packages/10.5.8 Cups Fix.pkg...
Caching package...
Downloading BOM for com.mydomain..mail_cert.pkg...
Downloading Components of http://JSS.mydomain.com:80/CasperShare/Packages/com.mydomain..mail_cert.pkg...
Caching package...
Downloading BOM for Install Wacom Tablet.pkg...
Downloading Components of http://JSS.mydomain.com:80/CasperShare/Packages/Install Wacom Tablet.pkg...
Downloading BOM for Sophos AA Remove Anti-Virus.pkg...
Downloading Components of http://JSS.mydomain.com:80/CasperShare/Packages/Sophos AA Remove Anti-Virus.pkg...
Installing Sophos AA Remove Anti-Virus.pkg...
Succesfully installed Sophos AA Remove Anti-Virus.pkg.
Caching package...
Downloading BOM for ctclient.pkg...
Downloading Components of http://JSS.mydomain.com:80/CasperShare/Packages/ctclient.pkg...
Caching package...
Downloading BOM for Sophos Anti-Virus.mpkg...
Downloading Components of http://JSS.mydomain.com:80/CasperShare/Packages/Sophos Anti-Virus.mpkg...
Installing 10.5.8 Cups Fix.pkg...
Succesfully installed 10.5.8 Cups Fix.pkg.
Installing Install Wacom Tablet.pkg...
Installation failed. The installer reported: 2010-06-29 08:25:22.559 installer[8919:3113] PackageKit: ** Missing bundle identifier: /Library/Receipts/10.5.8 Cups Fix.pkg
2010-06-29 08:25:22.562 installer[8919:3113] PackageKit: *
* Missing bundle identifier: /Library/Receipts/Tweetie_1.2.4.pkg
installer: Package name is Wacom Tablet
installer: Installing at base path /
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Installing Sophos Anti-Virus.mpkg...
Succesfully installed Sophos Anti-Virus.mpkg.
Installing com.mydomain..mail_cert.pkg...
Succesfully installed com.mydomain..mail_cert.pkg.
Installing ctclient.pkg...
Succesfully installed ctclient.pkg.
Downloading http://JSS.mydomain.com:80/CasperShare/Scripts/fix_printer_pause.sh...
Running Script fix_printer_pause.sh...
Script Exit Code:0
Script Result: Record was not found.
Downloading http://JSS.mydomain.com:80/CasperShare/Scripts/setsoftwareupdate.sh...
Running Script setsoftwareupdate.sh...
Script Exit Code:0
Script Result: 2010-06-29 08:26:03.452 system_profiler[9669:903] Exception while calling [SPSerialATAReporter updateDictionary:]
*** -[NSCFDictionary setObject:forKey:]: attempt to insert nil value (key: _name)
Running Recon...
Gathering Application Usage Information...
Finding Extension Attributes...
Be the first to reply!
