Force installation of certain apps for certain departments but put them in self service for others
  • February 8, 2017
  • 4 replies
  • 73 views
As described in the subject.
I'm looking at forcing installation of certain apps for certain Smart Mobile Device/Network Segments/.... groups whilst making them available for other groups in the Self Service Store.
Do I best work with each network segment and assign apps through that or do it otherwise?
The setup I have is currently used for 2 schools (segments) and others get added afterwards.
Also how do I use 1 VPP account for multiple segments?
Kind regards.
  • February 8, 2017
I have two of the same App in the JSS, one is for Self Service the other for Push.
Not sure if this is the best practice but it works.
scottb
  • February 8, 2017
I do it like @paulvb above. It's relatively easy as you can clone the first policy and modify it, making the name include something obvious like "Manual Install GoogleChrome-56.0.2924.87". or "Self Serve GoogleChrome-56.0.2924.87"
There may be more sophisticated ways, but in lieu of that, this works well.
  • February 15, 2017
True, this works, but if you have a LOT of apps, this becomes ridiculous. I currently have 480 apps in our JAMF. I would need to duplicate each, then make a category for each so I could distinguish it easily. This would mean I would have 960 apps in JAMF. JAMF is slow enough as it is bringing up the Mobile Apps list, I would hate to think what would happen if I duplicated all our Apps.
JAMF needs to come up with another way of handling this elegantly.
Still wish JAMF would use Tags similar to Meraki…
  • September 29, 2023
Hopefully this is still relevant, but how do you get two instances of the same app in JSS? Thanks!
