Certs not appearing in Recon nor Composer
  • October 15, 2015
  • 0 replies
  • 10 views
I have installed my Apple Developer & Installer certs. I can sign in Packager fine. But the option in dropdown prefs for Composer and Recon will not show my Dev/Installer cert. Therefore I can't sign Composer packages & Quickadd.pkg. I could have sworn I had this working in 10.10. Is there a trick to this?
I realize I need to import the Apple Dev ID intermediate certs as shown here
https://jamfnation.jamfsoftware.com/article.html?id=294
Here is what I have tried this far.
I have tried the importCACert.sh method
https://jamfnation.jamfsoftware.com/viewProductFile.html?fid=459
I have tried importing and trusting via terminal :
sudo /usr/bin/security add-trusted-cert -d -r trustRoot -k /Library/Keychains/System.keychain DeveloperIDCA.cer
sudo /usr/bin/security add-trusted-cert -d -r trustRoot -k /Library/Keychains/System.keychain AppleWWDRCA.cer
I have also followed the guide provided by @rtrouton
https://derflounder.wordpress.com/2012/08/13/creating-apple-developer-id-signed-casper-quickadd-installer-packages/
I have also tried manually importing into keychain access
I'm at a loss ;( anyone have any suggestions?
