Casper Imaging compile issues?
  • July 6, 2010
  • 32 views
Hello,
I've been banging my head against the wall for a few days on this now, and I can't figure out what might be going on with it...
We've got a big hardware rollout coming up in a few weeks, so I'm working on getting all of our configurations in proper order, compiled, and ready to go. I'm compiling on 3 different machines to speed up the process (and because I have to, with some configurations being i5/i7 specific)
I was able to compile some of the configurations with no issues, but on the remaining ones, the compile process either kernel panics the machine, or tosses me back an error message saying:
"The package installation failed. Here is the message:
Installation failed. The installer reported: 2010-07-06
09:59:17.447 installer[1209:3007] PackageKit: Applications
Library Network System Users Volumes bin cores dev etc home
mach_kernel net private sbin tmp usr var Missing bundle
identifier: /Volumes/i5 i7 Macintosh Video - Premiere Pro 10.6/
Library/Receipts/Cisco VPN Client.pkg
09:59:17.452 installer[1209:3007] PackageKit: Applications
Library/Receipts/vpnclient-api.pkg
09:59:17.459 installer[1209:3007] PackageKit: Applications
Library/Receipts/vpnclient-bin.pkg
09:59:17.461 installer[1209:3007] PackageKit: Applications
Library/Receipts/vpnclient-gui.pkg
...(more of the same)
Installer: Package name is SF Fonts
Installer: Installing at base path /Volumes/i5 i7 Macintosh Video - Premiere Pro 10.6
Installer:PHASE:Preparing for installation
Installer:PHASE:Preparing the disk
Installer:PHASE:Preparing SF Fonts
Installer:PHASE:Waiting for other installations to complete
Installer:PHASE:Configuring the installation
Installer:STATUS:
2010-07-06 09:59:18.650 installer[1209:7603] PackageKit: ApplicationsLibrary Network System Users Volumes bin cores dev etc home mach_kernel net private sbin tmp usr var Missing bundle identifier: /Volumes/i5 i7 Macintosh Video - Premiere Pro 10.6/
2010-07-06 09:59:18.651 installer[1209:7603] PackageKit: ApplicationsLibrary Network System Users Volumes bin cores dev etc home mach_kernel net private sbin tmp usr var Missing bundle identifier: /Volumes/i5 i7 Macintosh Video - Premiere Pro 10.6/
etc..."
Then it goes into installing, and gives percentage updates. The window is too big for me to see any more of the error message after that.
If I remove the fonts package, it crashes on another package, but it always seems to return these VPN-related errors. Even if I remove any Cisco VPN package from the configuration...
Any help would be greatly appreciated.
Thank you,
Bob Feldhake
  • July 6, 2010
It is a problem if it keeps the configuration from compiling completely...after I get these errors Casper Admin returns to the packages window and the configuration remains uncompiled.
  • July 6, 2010
We get the same errors with VPN Client, Jamf told us not to worry about it, and these are not any real problem.
Patrick Bachuwa
Client Technical Services
Sears Holdings Corporation
Michigan Campus
3000 W. 14 Mile Road
Royal Oak, MIĀ  48073-1717
Phone: 248 637-0350
Patrick.Bachuwa at searshc.com
