Unable to Connect to the MDM Server for your Organization
  • April 13, 2018
  • 39 replies
  • 280 views
  • Attempting to initiate Zero Touch Deployment with DEP enrolled MacBook Pro.
  • After entering login info at the "Select Your Wi-Fi" prompt, the Remote Management screen appears.
  • Click the Continue button and a "Unable to Connect to the MDM Server for your Organization" appears.
  • Attempted the same process on both a public Wi-Fi network and on the company Wi-Fi network. Got the same result.
  • Does a port need to be opened or some other configuration need to the modified?
  • April 13, 2018
Do you have a certificate payload in the PreStage? I had to remove the built in anchor cert payload in order to get the PreStage to work.
  • April 13, 2018
I am having the same issue, and I dont have a cert payload.
  • April 13, 2018
I've seen this and all I needed to do to resolve it was to reformat the machine.
  • April 13, 2018
I just finish repartitioning a Mac and I still get the same error.
  • April 13, 2018
How about can you reach your JSS from the same network that you are trying to enroll on?
C
  • April 13, 2018
I saw this for the first time today testing DEP on one machine while a different machine worked fine. Came back an hour later and the machine throwing this error went through DEP without issue..
  • April 18, 2018
Yes, my Jamf Pro Rep had me remove the Anchor Cert payload. Also, I reinstalled the macOS on the DEP enrolled MacBook Pro two times but got the same result.
* Tried using the company public Wi-Fi, my cell phone hot spot, my Wi-Fi at home, the free public Wi-Fi in a community center; the Wi-Fi in a public library - result: the same "Unable to configure your Mac..."
easyedc
  • April 18, 2018
@SVC-SBDJamfAdmin do you have any network filtering/NAC in place? We use Forescout and for us if our key isn't there or the MAC address of my dongle isn't trusted through our DHCP filter, (or we placed on a dedicated build segment) our DEP doesn't reach both Apple and our internal JSS JAMF Pro and the DEP fails. What I have seen is that I can usually take it to the GUI and it will DEP enroll there with a
sudo profiles renew -type enrollment
but that only applies to 10.13 machines.
  • April 20, 2018
@easyedc Hi, We have NAC in place and we are seeing the same issue. If I do "no network" at setup assistant and try the (sudo profiles renew -type enrollment" command I get an error that a certificate chain is not configured properly.
Once I install our company cert, I can install the profile.
Do I need to upload our company cert as an anchor certificate in the DEP PreStage?
  • May 10, 2018
Did anyone get this resolved? I've just started experiencing same problem, but it all used to work a month or two ago when I've tested last. The only change happened since was me upgrading our JSS to 10.3.1.
I am also having the same issue. I have tried multiple different networks to include wired and wifi. We also have a separate external network for our department that isn't part of the regular network and that is no bueno either. I got it to work one time out of 4 machines this week by reinstalling macOS but beyond that each one I have done the same thing to it has not worked.
We have also started to run into this issue frequently. During employee onboarding on the 22nd we had the issue occur across 3 separate offices at the same time. Today while doing a hardware upgrade for an employee we ran into the same issue. We initially thought it may have been network congestion during our onboarding, but today proved otherwise.
I was able to scope a prestage to my laptop and run the sudo profiles renew -type enrollment and receive the error as well. I've reached out to jamf support, but if anyone has any interim solutions that would be awesome.
  • May 29, 2018
Have you tried on an external network? Quite possible you need to make sure the correct ports are open. We had this previously where DEP worked in one office and didn't in another.
This is what JAMF supplied:
https://www.jamf.com/jamf-nation/articles/34/network-ports-used-by-jamf-pro
Be sure to allow outbound connections to Apple’s 17.0.0.0/8 block over TCP port 5223 / 443 from all client networks and on ports 2195 and 2196 from Jamf Pro servers to make sure APNs will function correctly on your network.
Yup we've trie dover multiple networks, as well as connecting through a mobile hotspot. I'll pass some of those details to our networking team as well just to review the ports.
  • June 5, 2018
Following this. Having the same issue. I've worked with JAMF CS and they are researching a solution, but nothing yet. Sorry to say it's kind of nice know that I'm not the only one.
  • June 6, 2018
I am following because I am now seeing problems with this same thing.
  • June 6, 2018
This is also happening to me. I just updated to 10.4.1.
  • June 6, 2018
i saw this today for about an hour but now it's working again.
  • June 21, 2018
Has anyone heard a solution for this yet?
  • June 21, 2018
Something is broke at Jamf and they don't seem to be too quick to acknowledge or fix it. I'm new to Jamf so I'm wondering if this is typical? I've attempted to get two brand new MacBook Pros into DEP from work and home resulting in the same configuration error window. So far the Jamf Support people I've talked with are only offering desperate guesses. If you haven't opened a ticket yet please do so!
  • July 3, 2018
We also saw this same problem , We tried to create new prestage enrollment, reformat device so many times, also update the DEP token problem still cannot solved. Any solution?
  • July 18, 2018
Anyone had any luck diagnosing this yet? I'm starting to see same issue in our test lab.
Well, I say same, it's likely closely related...
Running sudo profiles renew -v -type enrollment gives an Error -34006. I cannot find any reference to this on the inter tubes..
  • July 18, 2018
And in fact -34011 error too...
As you can see below, we're definitely ok out to Apple on 5223/443
dep-test-machine:~ testuser$ ~/telnet 5-courier.push.apple.com 5223
Trying 17.249.108.77...
Connected to pop-namer-ne-courier.push-apple.com.akadns.net.
Escape character is '^]'.
telnet> quit
Connection closed.
dep-test-machine:~ testuser$ ~/telnet 5-courier.push.apple.com 443
Trying 17.249.108.90...
ehlo
Connection closed by foreign host.
dep-test-machine:~ testuser$ sudo profiles renew -verbose -type enrollment
Password:
profiles: verbose mode ON
profiles: returned error: 34011
  • July 20, 2018
I am currently seeing this issue as well. We are starting to move to DEP for faculty now and not just labs. I need a solution before school starts again. Between our ordering process on campus and the DEP troubles, I am wondering if this is worth the transition. I would be interested to know the number of admins that use DEP for a majority of their devices.
  • July 20, 2018
I am seeing this also on a batch of Macs we are trying to enroll. Was working yesterday.
