Hi All,
I'm trying to automate the actual Computer to Site assignment via API as we keep on having Computers assigned to wrong Sites.. :) So far I have not had much success, does anyone maybe have an idea how to tackle this?
Hi All,
Best answer by ChupSuy
As promised, here my complete script to Bulk Update all Computer Group members to Site Y...
I hope it can be of help to others as well...
The script is tested in our companies JSS environment and multiple groups with a large count of nodes, however, the execution of any script is on your own risk.
# Script Name: API_GroupComputersToSite.sh
# Author: Sven Ramm
# Date: 02/13/2017
# Version: 1.0
# Purpose: Bulk assign all Computer members of group X to Site Y
# Changes: - 02/13/2017
# - Script creation
## Change these 3 variables to match your setup. API account must have API write privs
apiUser="YourAPIUser"
apiPass="Your API User Password"
jssURL="https://YourJSS.com:8443"
tmpXML="/tmp/site_location.xml"
logFile="/var/log/JAMF_API.log"
if [[ -z "$apiUser" ]] || [[ -z "$apiPass" ]] || [[ -z "$jssURL" ]]; then
echo "The API username, password or JSS URL were not specified in the script. Please add these details and try again."
exit 1
# Function to provide logging of the script's actions to
# the log file defined by the logFile variable
Logging(){
DATE=`date +%Y-%m-%d %H:%M:%S`
LOG="$logFile"
echo "$DATE" " $1" >> $LOG
# Function to create the basic XML informations to be PUT via API
WriteUpdateXML () {
local SiteID=$1
local SiteName=$2
## Create the xml for upload via API
echo "<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<computer>
<general>
<site>
<id>$SiteID</id>
<name>$SiteName</name>
</site>
</general>
</computer>" > "$tmpXML"
# Function to Find ALL computers in a Group and assign these to a given Site
AssignGroupComputersToSite () {
local GroupID=$1
local SiteID=$2
local SiteName=$3
Logging "Group ID: $GroupID"
Logging "Site ID: $SiteID"
Logging "Site Name: $SiteName"
echo "Please wait & be patience..."
echo "You may monitor any progress in $logFile"
echo "Assigning Computers of Group ID: $GroupID, to Site $SiteName"
# Write tmp XML file
WriteUpdateXML "$SiteID" "$SiteName"
#GET API Resources from
local APIResource="/JSSResource/computergroups/id/$GroupID"
# Get ALL Computers which are members in SmartGroup
local ComputersInGroup_XML=`/usr/bin/curl -X GET -H"Accept: application/xml" -s -u "$apiUser:$apiPass" ${jssURL%/}${APIResource}`
local COUNT=`echo $ComputersInGroup_XML | /usr/bin/xpath "/computer_group/computers/size/text()" 2> /dev/null`
# Loop through the X results
for (( INDEX=1; INDEX<=$COUNT; INDEX++ )); do
COMPUTER_ID=`echo $ComputersInGroup_XML | /usr/bin/xpath "/computer_group/computers/computer[$INDEX]/id/text()" 2> /dev/null`
COMPUTER_NAME=`echo $ComputersInGroup_XML | /usr/bin/xpath "/computer_group/computers/computer[$INDEX]/name/text()" 2> /dev/null`
AssignGroupComputersToSite=$(curl -sfku "${apiUser}":"${apiPass}" "${jssURL}/JSSResource/computers/id/${COMPUTER_ID}" -T "$tmpXML" -X PUT)
if [ $? == 0 ]; then
Logging "Count: $INDEX Successful updated Site data for: $COMPUTER_NAME"
Logging "Count: $INDEX Failed to update Site data for: $COMPUTER_NAME"
#sleep 0.5
done
# to find ALL Site names & ID's assosiated check the API help @ https://YourJSS.com:8443/api/#!/sites
# to find Group names & assosiated Group ID's check the API help @ https://YourJSS.com:8443/api/#!/computergroups/findComputerGroups_get
# USAGE: AssignGroupComputersToSite "Group ID" "Site ID" "Site Name"
# Empty Log File for today's run
cat /dev/null > $logFile
# Assign members of Group "Example All Berlin Computers" Group ID: 59 to Site ID: 6 Site Name: "Berlin"
Logging "######################################################################"
Logging "START assigning Group Computers to Site #"
AssignGroupComputersToSite "59" "6" "Berlin"
Logging "END assigning Group Computers to Site #"
exit 0Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
