Does Casper Imaging in 9.93 enable ARD by default?
  • February 13, 2017
  • 26 views
I know this seems like a naive question but I think I remember that in newer versions of Casper, there was no need to have a firstboot script to kickstart ard? IIRC screensharing would be on but the check box in SysPrefs>Sharing wouldn't be ticked and only the management account would have rights to screenshare on the box? Maybe?
The reason I ask is that lately machines that are going through Casper imaging don't have ARD enabled at all...
I use AutoCasperNBI to build my NBI's and do't do anything more exotic than that.
Best answer by canopimp
No it does not. You will need to do that following imaging via a script. I have a policy setup in our environment that enables ARD for our local admin account and then I use an Extention Attribute to check to see if ARD is enabled. If it is not, then I have a policy run the script again to keep ARD enabled on the machines. The ARD script if aviailable from the JAMFNation scripts section here.
  • February 13, 2017
  • February 14, 2017
Thank you @canopimp That's gonna save from a really deep rabbit hole :)
