macOS Sierra 10.12.3
  • November 22, 2017
  • 6 replies
  • 38 views
Has anyone got a 10.12.3 lying around somewhere that you can send me pls?
Need to use JAMF's in place upgrade and not the script hence want the older one. Thanks!
Best answer by kowsar_ahmed
Thanks for the offer @Nix4Life I did get it sent over!
cubandave
  • November 22, 2017
What exactly are you trying to do?
In place upgrade from what to what?
Jamf supports in place upgrades with the Mac App Store OS Installer. All you have to do is drag and drop the installer in to Jamf Pro Admin.app and add that to a self service.
http://docs.jamf.com/technical-papers/casper-suite/deploying-osx/Deploying_an_OS_X_Upgrade.html
Demo available in this webinar
https://www.jamf.com/resources/webinar/managing-ios-11-and-macos-high-sierra-upgrades/
  • November 22, 2017
@cubandave That method no longer works on clients running 10.12.4 or later afaik. Or does this work again under Jamf Pro 10?
I believe this is the script being referred to.
https://github.com/kc9wwh/macOSUpgrade
I don't have any issues with this script however (we made slight modifications). Roskos did a bang up job with this script.
I only saved a 10.12.6 installer so I don't have a pre .4 I'm afraid.
  • November 23, 2017
Thanks @Kaltsas and yes that is why I need the pre .4 version. Haven't tested on JAMF PRO 10 yet but I'm sure it won't work as it was an Apple restriction that broke it and not JAMF. The script gave me a few authenticated restart issues sporadically hence I'll just rather do the in-place method as I have quite a few remote Macs that need upgrading without being physically present.
  • November 25, 2017
@kowsar.ahmed,
I have a copy as an .app and as a .pkg via createOSXinstallpkg
  • November 27, 2017
  • November 27, 2017
I saw you got this, but I have the raw download of 10.12.3 if you need it. I save full version downloads of each point release as they come down if anyone needs one.
