Is there a way to find Skype version in all the managed mac devices in my company?
I tried with the extension attribute but the script is not populating the results.
Best answer by millersc
# Gets currently installed version of Skype for Business
if [ -f "/Applications/Skype for Business.app/Contents/Info.plist" ] ; then
VERSION=$( defaults read '/Applications/Skype for Business.app/Contents/Info.plist' CFBundleShortVersionString )
VERSION="Not installed"
echo "<result>$VERSION</result>"
Try this. Remember it does need to do a recon before it will populate EA's. It's only going to be the version number (16.3.241) or Not Installed.
