Xcode 9 Beta for non admin users
  • June 28, 2017
  • 11 replies
  • 87 views
Did anyone upon installing the script which was used for xcode 8 users are now faced with admin prompt to install the tools in xcode beta 9 even though they are part of the dev security group
# Accept EULA so there is no prompt
if [[ -e "/Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild" ]]; then
  "/Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild" -license accept
# Just in case the xcodebuild command above fails to accept the EULA, set the license acceptance info
# in /Library/Preferences/com.apple.dt.Xcode.plist. For more details on this, see Tim Sutton's post:
# http://macops.ca/deploying-xcode-the-trick-with-accepting-license-agreements/
if [[ -e "/Applications/Xcode.app/Contents/Resources/LicenseInfo.plist" ]]; then
   xcode_version_number=`/usr/bin/defaults read "/Applications/Xcode.app/Contents/"Info CFBundleShortVersionString`
   xcode_build_number=`/usr/bin/defaults read "/Applications/Xcode.app/Contents/Resources/"LicenseInfo licenseID`
   xcode_license_type=`/usr/bin/defaults read "/Applications/Xcode.app/Contents/Resources/"LicenseInfo licenseType`
   if [[ "${xcode_license_type}" == "GM" ]]; then
       /usr/bin/defaults write "/Library/Preferences/"com.apple.dt.Xcode IDEXcodeVersionForAgreedToGMLicense "$xcode_version_number"
       /usr/bin/defaults write "/Library/Preferences/"com.apple.dt.Xcode IDELastGMLicenseAgreedTo "$xcode_build_number"
       /usr/bin/defaults write "/Library/Preferences/"com.apple.dt.Xcode IDEXcodeVersionForAgreedToBetaLicense "$xcode_version_number"
       /usr/bin/defaults write "/Library/Preferences/"com.apple.dt.Xcode IDELastBetaLicenseAgreedTo "$xcode_build_number"
# DevToolsSecurity tool to change the authorization policies, such that a user who is a
# member of either the admin group or the _developer group does not need to enter an additional
# password to use the Apple-code-signed debugger or performance analysis tools.
/usr/sbin/DevToolsSecurity -enable
# Add all users to developer group, if they're not admins
/usr/sbin/dseditgroup -o edit -a everyone -t group _developer
# If you have multiple versions of Xcode installed, specify which one you want to be current.
/usr/bin/xcode-select --switch /Applications/Xcode.app
# If you have multiple versions of Xcode installed, this will point the command line tools to current version
sudo xcode-select -s /Applications/Xcode.app/Contents/Developer/
# Bypass Gatekeeper verification for Xcode, which can take awhile.
if [[ -e "/Applications/Xcode.app" ]]; then xattr -dr com.apple.quarantine /Applications/Xcode.app
# Install Mobile Device Packages so there is no prompt
if [[ -e "/Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg" ]]; then
  /usr/sbin/installer -dumplog -verbose -pkg "/Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg" -target /
if [[ -e "/Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg" ]]; then
  /usr/sbin/installer -dumplog -verbose -pkg "/Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg" -target /
# Install XcodeSystemResources.pkg so there is no prompt
if [[ -e "/Applications/Xcode.app/Contents/Resources/Packages/XcodeSystemResources.pkg" ]]; then
  /usr/sbin/installer -dumplog -verbose -pkg "/Applications/Xcode.app/Contents/Resources/Packages/XcodeSystemResources.pkg" -target /
  • June 28, 2017
@MaCaDmIn82 I don't have an answer to your Xcode question, but if you want to paste code into a forum post either use the >_ icon above the response block to add a Markdown tag, or use a triple backtick (```) before and after your code so that it appears properly in your post.
  • June 28, 2017
up
  • June 28, 2017
You missed a package. Add:
# Install XcodeExtensionSupport.pkg so there is no prompt
if [[ -e "/Applications/Xcode.app/Contents/Resources/Packages/XcodeExtensionSupport.pkg" ]]; then
  /usr/sbin/installer -dumplog -verbose -pkg "/Applications/Xcode.app/Contents/Resources/Packages/XcodeExtensionSupport.pkg" -target /
before the
Also unless you changed the name of the app to Xcode.app, you need to change all occurrences of Xcode.app in the script to Xcode-beta.app
  • June 29, 2017
Still getting a prompt for "Install additional required components
donmontalvo
Forum|alt.badge.img+36
  • June 29, 2017
  • July 19, 2017
@Byte @donmontalvo any luck with your implementations? I'm receiving the same dialog message from the installation of any Xcode 8.3.x version?
  • September 20, 2017
For Xcode 8.3.3 the following script worked for us:
#/usr/bin/xcode-select --switch /Applications/Xcode.app
For Xcode 9 it doesn't. Has anyone already fixed / updated the script to work with xCode 9?
No longer in .edu, but did use the script noted here, so are the command line tools baked in now? Asking because in the past we had to be explicit and call them prior to launch, but I don't see the command for that in this script
# Installing the Xcode command line tools on 10.7.x or higher
osx_vers=$(sw_vers -productVersion | awk -F "." '{print $2}')
cmd_line_tools_temp_file="/tmp/.com.apple.dt.CommandLineTools.installondemand.in-progress"
# Installing the latest Xcode command line tools on 10.9.x or higher
if [[ "$osx_vers" -ge 9 ]]; then
    # Create the placeholder file which is checked by the softwareupdate tool
    # before allowing the installation of the Xcode command line tools.
    touch "$cmd_line_tools_temp_file"
    # Find the last listed update in the Software Update feed with "Command Line Tools" in the name
    cmd_line_tools=$(softwareupdate -l | awk '/* Command Line Tools/ { $1=$1;print }' | tail -1 | sed 's/^[[ 	]]*//;s/[[ 	]]*$//;s/*//' | cut -c 2-)
    #Install the command line tools
    softwareupdate -i "$cmd_line_tools" -v
    # Remove the temp file
    if [[ -f "$cmd_line_tools_temp_file" ]]; then
      rm "$cmd_line_tools_temp_file"
RobertHammen
Forum|alt.badge.img+29
  • September 21, 2017
I'm using the below script to install the built-in packages... as for the additional command-line packages, I used SUS Inspector to capture them and include them in the deployment policy.
#/usr/sbin/dseditgroup -o edit -a everyone -t group _developer
# Bypass Gatekeeper verification for Xcode, which can take hours.
#if [[ -e "/Applications/Xcode.app" ]]; then xattr -dr com.apple.quarantine /Applications/Xcode.app
#fi
# Install Mobile Device Packages so there are no prompts
# Install Command Line Tools.
if [[ /usr/bin/xcode-select ]]; then
    /usr/bin/xcode-select --install
# Allow any member of _developer to install Apple-provided software.
# be sure you really want to do this.
/usr/bin/security authorizationdb write system.install.apple-software authenticate-developer
RobertHammen
SUS Inspector
Here's a list of recent updates:
Here are the packages included in that distribution - note that I'm only installing this on Sierra right now, and only installing the "CLTools_Executables.pkg" and the "DevSDK_OSX10.12.pkg" in my policy, haven't yet worked out the "Remove_101x.pkg" packages or installed the "CLTools_SDK_macOS10.13.pkg"
jartron3030
  • January 10, 2018
@RobertHammen I have a policy scoped to a computer lab to install Xcode 9. I then used the above script as a post install script, although I did not include the command-line packages in the deployment. I have confirmed that Xcode was installed successfully, but now every computer in this lab is periodically and repeatedly getting the following prompt...
I am at a loss to how to make this stop. I can cancel and the prompt will go away for a while, but then return. I can type in my AD credentials and our local admin credentials and it will then go away, but then return...
Any ideas or thoughts?
