MakeMeAdminPy
  • November 27, 2017
  • 7 replies
  • 53 views
Trying to implement Temporary Admin Self Service for our developers, as they require periodic updates to installed software. Much easier if users can install what they needed. The script was originally written by Joshua Roskos. Stuck trying to figure out the variables to make the script work in our environment.
https://github.com/kc9wwh/MakeMeAdminPy
Variables
grantTempAdmin.py - Lines 72-79
removeTempAdmin.py - Lines 70-77
EA-MakeMeAdmin_ComplianceCheck.py - Lines 5-6
Thanks
  • December 12, 2017
Were you able to implement MakeMeAdminPy. I am trying to figure this out, myself?
  • December 12, 2017
hi , Can I get this script in Shell?
  • December 12, 2017
Maybe give this one a try as a shell script:
https://github.com/MacTool/JSS-Public/tree/master
Haven't tested it outside my environment yet, but may be helpful.
  • December 13, 2017
Nope, still haven't figured out MakeMeAdminPy.
Currently using script posted by JPDyson https://www.jamf.com/jamf-nation/discussions/6990/temporary-admin-using-self-service
  • December 14, 2017
I would like to what to select once in smart groups...
Step 3 - Configure the Smart Group
Create a Smart Group named "MakeMeAdmin - Violations" and ensure "Send email notification on membership change" is enabled.
And/Or Criteria Operator Value MakeMeAdmin - Compliance Status Like Remediated
Or MakeMeAdmin - Compliance Status Like Violation
  • December 22, 2017
Anyone getting "Violation - No newAdmins - orgAdmin ERROR" ?
  • January 3, 2018
To Simon.L: I added both scripts to Jamf. How are the policies setup for this to take effect? I know that the tempadmin script works, but I am not able to get the second script to execute.
