Extension attribute to check what shell root has
  • November 28, 2017
  • 0 replies
  • 6 views
Just created this due to the root vulnerability discovered today (2017-11-28)
<?xml version="1.0" encoding="UTF-8"?><extensionAttribute>
<displayName>Root shell</displayName>
<description>Check root's login shell</description>
<dataType>string</dataType>
<scriptContentsMac>#!/bin/sh&#13;
&#13;
result=$(sudo dscl . -read /Users/root UserShell | awk '{print $NF}')&#13;
&#13;
echo "&lt;result&gt;$result&lt;/result&gt;"&#13;
</scriptContentsMac>
<scriptContentsWindows/>
</extensionAttribute>
If $result is /usr/bin/false, you should be ok according to #security at the Macadmins slack
