What i want to do is when a machine is done imaging via DEP it sends an email to an account with serial number, user and model. This I have working in a script. I now what to add a list of applications that are installed, when it completes.
I want to run this script first and then attach the file applist.txt
!/bin/bash
get list of all current apps installed
appVersionList=$(mdfind -onlyin /Applications 'kMDItemContentType==com.apple.application-bundle' -attr "kMDItemDisplayName" -attr "kMDItemVersion" | sed 's/^.*kMDItemDisplayName//' | sed 's/kMDItemVersion//g' | tr '=' ' ' | sort >> /tmp/applist.txt)
Here is the script for sending the email.
!/bin/bash
sHost=$(networksetup -getcomputername)
theserial="$(ioreg -l | grep IOPlatformSerialNumber | sed -e 's/."(.)"/1/')"
sUser=$(id -F) # this finds system admin as it is running using sudo
user=$(ls -l /dev/console | awk '/ / { print $3 }')
model=$(ioreg -l | awk '/product-name/ { split($0, line, """); printf("%s ", line[4]); }')
echo $sHost
echo $theserial
echo $model
echo $user
mail -s "Apple DEP Image Completed: $sHost" "it@corp.com" <<EOF
DEP imaging done for machine $sHost
Serial: $theserial
User is: $user
Model is: $model
EOF
Anyone know the command lines to do this.
Sure, remove the (below) so the list of apps remains in the appVersionList variable. Now copy this line to the email script and you'll be able to do Apps are: $appVersionList.
>> /tmp/applist.txt
