We have had an interesting scenario come up that falls somewhere in between Apple and JAMF as far as how to set things up. I think we can do this, but I wanted to get a sanity check from JAMF Nation since nobody can tell me 100% for sure whether this idea will work without screwing something up.
My organization wishes to buy about twenty iPads for use by student teachers in a K-12 environment. Between OSU and the K-12 organization, we have decided that it will make more sense for the K-12 organization to manage the iPads since they need to be set up identically to how the other iPads in the K-12 institution are set up. So the iPads will then be physically transferred to that K-12 institution and they will take on management of the devices.
The K-12 institution is using Apple DEP for all of their iOS devices and we would like to stay consistent with that model, both so that we can take advantage of the benefits of DEP, and so that we do not cause the other organization to have to set up an entirely separate way of doing things for devices that would have to be manually enrolled if they were not DEP enabled.
The easiest way to get the iPads to the K-12 organization is for OSU to purchase the iPads and then transfer them to the K-12 organization. If OSU signs over an amount of money for the K-12 organization to purchase the iPads, all of the sudden we end up in all kinds of red tape and legal paperwork that we are ultimately hoping to avoid, so what we are hoping to do is purchase the iPads through Apple DEP and then somehow get them auro-enrolled in the K-12’s Casper server via DEP.
We spoke to our Apple rep last week and confirmed that there is not a way for OSU to purchase the iPads and then transfer them into the K-12 organization’s DEP instance. In short, once we purchase the iPads they are permanently tied to our DEP instance.
Now, we think we have a workaround in the works, if the K-12 organization would agree to it, but I wanted to check and make sure that this would not negatively affect anything that is already in place.
I think we should be able to add the K-12 organization’s Casper server into OSU’s DEP instance so that we can register the iPads directly into their Casper server, without us needing to access their server directly or give them any sort of access to our DEP instance. It seems to me that this is how things would work:
• The K-12 JAMF admin downloads the public key (.pem) file from their JSS.
• The K-12 JAMF admin transfers the public key file to us (OSU).
• We log into our instance of the Apple Volume Services Portal, add an entry for their Casper server, and upload that public key file for that server.
• We download the resulting server token file (.p7m) and then transfer it back to the K-12 JAMF admin.
• The K-12 JAMF admin creates a DEP instance for us on their JSS and then uploads the server token file that we have provided into their JSS.
At that point, OSU should be able to assign any asset in our DEP instance to the K-12 Casper server, effectively transferring management of the devices to them without either party ever having direct access to the other party’s server, unless I’m missing something.
So the big question is, can a Casper server be assigned to two or more completely separate and unrelated DEP instances, or in other words, is there any danger that by adding their Casper server to our DEP instance that it would break their ability to use their Casper server within their own instance?
