Details about converting the MySQL DB to InnoDB
  • September 18, 2018
  • 4 replies
  • 30 views
About the InnoDB conversion and the tool to do it... We now have got the tool out from the Linux installer on a VM, and have run it on a dev instance. It asks for various values (pool size etc).
  • Is there any documentation about what these should be?
  • How do these values compare to existing values for MyISAM?
  • Where do they get written to?
  • What determines whether a newly created database is MyISAM or InnoDB? I don't see anything in the files in WEB-INF/xml/*?
  • Once we convert our existing DBs, how do we ensure that any new ones we make are already in InnoDB format?
  • Can the tool be run non-interactively so we can script it for all instances?
Serge
I though that if you didn't have
<DefaultStorageEngine>InnoDB</DefaultStorageEngine>
in your DataBase.xml file it'd default to MyISAM.
If I can add one more question: Are there any special concerns or a particular order of operations we should follow when converting on a multi-context server with multiple JPSes/databases or is it not a concern since the engine is a per-table thing and not a global database thing?
  • September 19, 2018
@Serge Where is this documented?
Serge
@grahamrpugh I don't think it was. I had to add that line for my new production instance to create InnoDB tables by default, and when I converted my staging instance to InnoDB. This was a couple of years ago, when InnoDB was unsupported still.
