Recently we became aware of a known Adobe Fuse issue (https://forums.adobe.com/thread/2131616) that's causing the application to fail to launch. Apparently the only work around at the moment is uninstalling and reinstalling the application entirely.
To create an on-demand fix for this issue for our students, I've cached a Fuse installer (/Library/Application Support/JAMF/Waiting Room/Fuse.pkg.zip) on the machines that are experiencing this issue. However, Casper Imaging automatically zips Adobe PKGs and I haven't found a way to via the command line to unzip these so that I can create a policy to install the cached Fuse PKG installer. I don't want to use the JSS "Install Cached" option as this will then delete the cached installer. This way students and teachers can run a reinstall policy from Self Service without needing to redownload the installer.
Looking for help with scripting the unzip as I currently get the following error:
bash-3.2# unzip -ofb /Library/Application Support/JAMF/Waiting Room/ADOBE_CC_2017_FUSE_Install.pkg.zip -d /Library/Application Support/JAMF/Waiting Room/ Archive: /Library/Application Support/JAMF/Waiting Room/ADOBE_CC_2017_FUSE_Install.pkg.zip warning [/Library/Application Support/JAMF/Waiting Room/ADOBE_CC_2017_FUSE_Install.pkg.zip]: 154754617 extra bytes at beginning or within zipfile (attempting to process anyway) error [/Library/Application Support/JAMF/Waiting Room/ADOBE_CC_2017_FUSE_Install.pkg.zip]: start of central directory not found; zipfile corrupt. (please check that you have transferred or created the zipfile in the appropriate BINARY mode and that you have compiled UnZip properly)
