Not Jamf related: iOS 11.1.2 and Work apps: Unable to initialize remote proxy for extension
  • November 30, 2017
  • 0 replies
  • 12 views
Hi all,
Has anyone run into this when trying to open Pages or Keynote on iOS?
Fully updated iPad and App versions, adequate room available on device
The app opens, then the error message: "Unable to initialize remote proxy for extension" shows when the document library is supposed to appear. Clicking cancel leaves a blank, black screen. Have also tried hard resets and reset all settings.
Also tried installing directly from the App Store. For two iPads, deleting and reinstalling the app resolved the issue, but app still not working on the other two. Thanks in advance for any insight or fix.
Sandy
