I am trying to set up something similar to our SCCM task sequence variables so that certain software programs are installed during netboot imaging only if a Mac has a specific naming convention. Here are a few examples:
If the Mac has this in the naming convention: TTD, TTL (Teacher CTE Desktop/Laptop) then it will install the ProTools software package in addition to the base level software programs for a teacher (Chrome, MS Office 2016, Lync, etc.)
If the Mac has this in the naming convention: TID, TIL (Teacher Instructional Desktop/Laptop) then it will install just the base level software programs for a teacher (Chrome, MS Office 2016, Lync, etc.)
All regular student named Macs should receive the same base level programs as teachers except Lync and Outlook.
My goal is to just use one configuration profile and then if possible use a script to determine by the naming convention which software would be installed during imaging. I do not have much experience with scripting. I have not been able to find anything on JAMF Nation. Is this something that can be scripted? Any suggestions?
