Hey guys.
I tried everything in Jamf nation and other sites.
I couldn't find any solution for my problem.
I'm trying to write a script that test the file existence and if its true he should do the A if not he should do B.
The problem is that nothing works when it comes to Current User location ( ~ ).
Not the $3 or anything else worked..
Oh and it should work with Altiris or any other deployment solution.
You just cant find a reason to love Mac :(
Can someone help me with this problem I'm stuck with?
~ always resolves to the home path of the account running the command. When scripts are run as root, ~ will resolve to /private/var/root/
If you're trying to test for something against the currently logged in user, you need to get the logged in user name first, and in some cases the home path, though the latter isn't necessary if you're certain the home folder will always be in /Users/ If they are, you just plug the current user name into a path like /Users/username/path/to/somefile Example below:
if [ -e "/Users/$loggedInUser/<rest of path here>/somefile" ]; then
    *do something*
    *do something else*
Hi Yarin,
I am a little unclear what you mean by "Current User location ( ~ )", but in bash, for instance, what you are looking for would be something like this -
filelookingfor="/pathtofile/filename"
if [ -f $filelookingfor ];
then
# found the file do something
echo "found file"
# didn't find the file, do something
echo "file not found"
@mm2270 posted a load of loop scripts. Can nest an if/else command into any of them for example.
Duplicate
Duplicate
@mm2270 I wrote a similar code and I don't know why but what you wrote works ! thanks !!!
I tested it on sierra and now I'll try to run it on other MacOS to be sure.
I'm using it to test if our Safari Extension product exist and if not remove it (and safari must be restarted)
The script will be used by costumers IT teams to deploy.
I'm sharing The code with you:
###     Function to Restart Safari from Last Session       ###
function ReSafari {
    echo "Restarting Safari to update WalkMe Extension removal"
    osascript -e 'tell application "Safari"
        quit
    end tell
    delay 2 -- Wait for Safari to close
    tell application "Safari" to activate
        tell process "Safari"
            click menu item "Reopen All Windows From Last Session" of menu "History" of menu bar 1
        end tell
    end tell'
### Checking for current user :
###           Function to Remove Extenion               ###
function UNEXTZ {
    ### Pull the current user
    ### Removing Extension extz from Safari Library
    echo "Removing WalkMe Extension from Safari library"
    RM /Users/$loggedInUser/Library/Safari/Extensions/Walkme Extension.safariextz
    ### Checking if extension exist after removal:
    echo "Checking if WalkMe Extension Was Removed properly"
    if [ -e /Users/$loggedInUser/Library/Safari/Extensions/Walkme Extension.safariextz ]; then
        echo "Could Not Remove WalkMe Extension"
        echo "WalkMe Has Been Successfully Removed"
        ### Enable the folowing Command to Restart Safari (To Compelete the Task You must Restart Safari!):
        ReSafari
###                       Script                           ###
### Checking if Extension is Installed:
    echo "WalkMe Extension IS Installed"
    UNEXTZ
    echo "WalkMe Extension NOT Installed!"
fi```
