Authrestart Script
  • October 7, 2016
  • 15 views
DBrowning
Is it possible to see the magic that is done when a policy has a reboot configured and the "Perform authenticated restart on comptuers with FileVault 2 enabled" box is checked?
Basically looking to see the script that is created/run.
donmontalvo
Forum|alt.badge.img+36
  • October 7, 2016
DBrowning
  • October 7, 2016
thats great. but i'm looking to do whatever magic it is that JAMF does as I don't want to have to prompt for the password or recovery key. I'm using the First boot install script to install a couple packages using while using COXIP to install Sierra.
