I was wondering if there is a way to pass Active Directory login and password resets through Jamf's traffic? I had seen an article a while back, but can't seem to find it now. (This would be for machines connecting that are not on our network).
Gabe Shackney
Princeton Public Schools
Are you referring to Infrastructure Manager? http://docs.jamf.com/infrastructure-manager/1.3.1/Jamf_Infrastructure_Manager_Overview.html
I don't believe this is possible. Maybe best to use an identity provider (Okta, Ping, etc...) for off network password changes. Infrastructure manager just proxies the connection between tomcat and your ldap/AD.
The infrastructure manager is probably what I was looking at. Does not look specifically like what I am wanting to do though.
Gabe Shackney
