BYOD Jamf Removal
  • July 12, 2017
  • 4 replies
  • 22 views
We recently let some BYOD devices enroll in JAMF but they are not company owned devices. The employees now want to get them unenrolled after learning what the MDM client abilities are. I know there is a command to remove the framework and unmage the macOS device. Though is there an easy way to remove any applications that were installed via enrollment script or self service ?
davidacland
  • July 12, 2017
Not easily. It depends on what apps have been deployed and the methods used (i.e. pkg installs, Mac App Store).
Adobe CC (for example) provide an uninstall package when you create a deployment package using creative cloud packager, but that is one specific case. Others might just need the .app bundle removing or a vendor script run.
Are there a lot of apps that have been deployed to the devices?
  • July 12, 2017
It can be anything that is offered in self service. Alot of them are mainly pkg files (ex: office 2016 , Cisco Anyconnect)
Chris_Hafner
Forum|alt.badge.img+27
  • July 27, 2017
This has been hanging out a while. What apps are you wondering about? You'll need an installation process for each and I'm sure we'd all be happy to advise.
  • July 27, 2017
I'd start by doing some searches for uninstall scripts for the various products you need to uninstall. Either vendor supplied ones, which do exist in some cases, or ones built by the Mac admin community. For example, @talkingmoose has had an uninstall script on his blog for a while to fully remove Office 2011. But that's an old app at this point. You mentioned Office 2016, and I'm sure it can be modified to work with version.
Since macOS doesn't really have a universal uninstall function like Windows, you will likely need to run various scripts to get the apps off the machines, at least in the case of items installed with regular package installers.
