I want to use Jamf to create a reboot alert when a Mac restarts. How would I do this?
Page 1 / 1
That is going to depend on how you are restarting the computer. Policies have the Restart Options and the User Interaction tab. If you are restarting from a script you can use JamfHelper to notify the user.
This would be if it went down due to power outage or something. Which I’m thinking now may not be possible.
