sysadminctl -secureTokenOn Returns "Unknown user" for Active Directory Account?
  • July 30, 2019
  • 4 replies
  • 63 views
Dear friends of the Secure Token,
I try to get a secure token for an active directory account. The AD user can login and is admin, but when I run
sysadminctl interactive -adminUser ladmin -adminPassword - -secureTokenOn adaccount -password -
I get prompted for the password of ladmin (which has a secure token), and then I see
sysadminctl[number1:number2] Unknown user adaccount
Any idea what is wrong here and how to fix this?
  • July 30, 2019
When logged in via the admin account I use.
sudo fdesetup list
sudo fdesetup remove -user first.last
Sysadminctl interactive -secureTokenOn first.last -password currentADPasswordhere
sudo diskutil apfs updatePreboot /
I'm not sure you can grant a secure token to a currently logged in account, only from an account that has one and is currently logged in.
  • July 30, 2019
I have tried this as local admin logged in, as the AD account logged in, with or without 'sudo', with or without 'interactive', I always get the 'Unknown user' - which is really strange when I am logged in as that user :(
I even tried a different AD account (defined directly, and not a member of a network group and added via scripts), but also there : 'Unknown user'.
How I love these precise and telling error messages.
Forum|alt.badge.img+15
  • July 30, 2019
@mschroeder What version of macOS are you running? There were some enhancements to securetoken behavior starting in 10.14.2 that are detailed in this post.
If your end goal is to have FileVault encryption enabled, just skip to enabling FileVault and macOS will auto sort out the securetoken and grant one to that AD account (assuming you're performing that command/action as the local admin user, not the AD account and running at least 10.14.2).
  • July 30, 2019
@sshort: I was testing on 10.14.6, so I should have profited from the enhancements in 10.14.2.
For now my goal is indeed enabling FileVault, but I wonder which other actions might require the Secure Token (now or in the future). I had tried try to enable FileVault, but it did not work. Seems I need to do some more reading on this.
