Delete applications without Adminrights withs self Service
  • July 31, 2019
  • 15 replies
  • 131 views
Since none of the users on our computer have no admin rights, but we have created a possibility that the user can uninstall App. However, the script only deletes the application from the folder. That is sufficient in most cases. However, in some cases it is necessary to delete the created data. Maybe someone has an idea how to find these and delete them.
# Shellscript : Uninstall Script
# Autor : Andreas Vogel,
# Script asks for the file to be deleted.
# Only for test - comment out in production!
# set -x
###### please only edit here
###### list files to protect here
app_protect="
NoMAD
McAfee
Self Service
Preproxy
Identity Agent
jamf"
##### End ################
# Variabeln
sys=$(while read p; do echo "$p" | grep "/Applications" ; done </System/Library/Sandbox/rootless.conf)
list="
$app_protect
$sys"
askapp () {
    /usr/bin/osascript <<EOF - 2>/dev/null
    set strPath to POSIX file "/Applications/"
    set f to (choose file with prompt "$1" default location strPath)
    set posixF to POSIX path of f
    tell application "Finder" to set filesDir to container of f as alias as text
    set posixDir to POSIX path of filesDir
    posixF
EOF
asknewdir () {
tell application "SystemUIServer"
    activate
    text returned of (display dialog "$1" default answer "")
end tell
EOF
app=$(askapp 'Please select the program to be deleted') || exit
# Loop for checking before deleting
for a in $list ; do
if [[ "$app" = *$a* ]]; then
osascript -e 'display dialog "This program can not be deleted!" buttons {"OK"} default button 1'
done
# Program is stopped and deleted
pkill -f "$app"
sudo rm -rf "$app"
osascript -e 'display dialog "The app has been deleted" buttons {"OK"} default button "OK"'
  • October 18, 2019
no ideas
alexduffner
  • February 8, 2023
Hi @avogel,
I have combined your idea with another and my own.
Perhaps the result will also serve your purposes:
https://github.com/aduffner/uninstallMacApps/blob/main/uninstallMacApps.sh
Pre-requisites: Installed https://github.com/bartreardon/swiftDialog (for the beautiful modals)
Best regards
Alex
tobiaslinder
  • May 22, 2023
Hi @avogel,
Best regards
Alex
Hey @alexduffner
Sadly the link to your uninstallMacApps doesn't work anymore. I would be really interested in your approach.
alexduffner
  • May 22, 2023
Hey @alexduffner
Hi @tobiaslinder, had set it to private for some reason, it's now public again.
Your and other's feedback is explicitly welcome. 😊
tobiaslinder
  • May 22, 2023
Thank you so much. You will hear from me, if I succeed at implementing your code in my project.
GraemeU
  • May 23, 2023
 Hi Alex
This script looks wonderful however during testing I was still prompted for admin creds when running via self service. - specifically Finder requesting to delete x files. Running on Ventura 13.4
GraemeU
  • May 24, 2023
 Hi Alex
Hi
Just to follow up, I ended up making some changes to the script to get this to work in my environment.
line 50 after add
trash() { mv "$@" /Users/$currentUser/.Trash/ ; }
line 186 remove
/usr/bin/sudo -u "$currentUser" osascript -e "tell application \\"Finder\\" to delete { $posixFiles }" >/dev/null
after add
echo "Moving app data to trash…" sleep 1 for item in "${paths[@]}" do Echo "Trashing $item ..." trash $item done
alexduffner
  • May 24, 2023
Hi
line 50 after add
line 186 remove
after add
Nice! Thank you for sharing, just request a pull request via Github - I will merge it :-)
GraemeU
  • May 24, 2023
Hi Alex, I will do some further testing before doing anything like this, for example the Zoom Outlook Plugin has a build in Uninstall.app which users cannot run, however if they try to remove it via the script, it will find a lot of things you dont really want to remove as part of the app. This is around the wildcard line 155.
paths+=($(find "$location" -iname "*$app_name*" -maxdepth 1
See below image
alexduffner
  • May 24, 2023
See below image
I think regex matches like these are the reason why nobody came up with an all-in-one uninstaller ^^
Thank you for testing. I would also recommend to not test it in the wild.
GraemeU
  • May 24, 2023
Hi Alex
Yes agree, this is a very tricky problem to solve but I think this script gets about 95% of the way there with no trouble, which is excellent. I have a small test group with this deployed now and will get feedback from users, mainly so I can round off our exclusion list.
I will just remind users to double check everything in the list prior to clicking ok! 😊
  • November 7, 2024
HI, Thanks for the script really appreciate the script. Just curious is there a way to restrict it to just application folder. So users can't go browsing all sort of directory. Like limiting it to just /Application folder only.
Thanks in advance
  • November 7, 2024
I just tried the script and it doesn't seem work.
Jacek_ADC
  • November 25, 2024
@alexduffner
Love your script. We just started to remove the adminrights on all our macbooks a few weeks ago.
Really nice done and i like your solution with swiftdialog. Great !!
a_martin253
  • March 20, 2025
Hi
line 50 after add
line 186 remove
after add
Thank you for this @GraemeU ! Those tweaks to the script worked perfectly! And thank you @alexduffner for building it out. I am going to see if I can fork it to add a swiftDialog check parameter into the script so it doesn't just fail out if it is missing /usr/local/bin/dialog
