We are having an issue with imaging with Casper Netboot (diskless).
The process appears to work however, when the machine finishes imaging
and reboots, the machine hasn't been imaged at all. It appears the
hard drive isn't being erased. I have successfully imaged if I use disk
util to erase the hard drive first.
Cynthia R. DuCharme
Technical Support SpecialistHelpdesk Support
VM 763-391-7221
