Hi All,
I have taken over from someone who implemented JAMF into the system. I have never really used the system and i am really struggling in getting 'Casper Imaging' to work.
I have made a Base High Sierra DMG via AutoDMG, but everytime i go to Image a laptop, it skips over the 'Base Image' package and then continues to try and install the other software packages.
The old Sys admin left images but they are all old (El Captain) but they work. I really wanted to get a new image made as having to update the laptops from El Captain to High Sierra is abit of a pain.
Im not really sure what i am doing wrong. I think that i might have something to do with the Casper software being out of date (???). Its currently running 9.81 and i am not sure how to update it. I am also having trouble getting the Casper Suite installed on my Mac as i keep getting 'Java 1.7 needs to be installed' even though i have Java installed.
Sorry if i wasnt that clear, i am very new to Jamf and Casper and i am still trying to figure out how everything works.
Any helps would be much appreciated.
