Hi all
Has anyone had any experience using McAfee File and Removable Media Protection to encrypt all external devices connected to the Mac ?
We're going down this road and just wondering if anyone has used FRP and if so what you've learnt
from the process.
I'm about to start testing it but i'm also looking to see if there are other ways that i can achieve what security requires without the need for McAfee. Maybe a way to detect any non network volumes
and bring up a jamfhelper or Cocoa dialog if they're not encrypted, then either eject or encrypt the device ?
hmmn, more coffee!
