Managed or Unmanaged
  • September 13, 2007
  • 0 replies
  • 1 view
Hello all,
I am looking to use policies to add software to our 200 Macs quickly and easily. After doing some testing I realised that if a Mac was in a non managed state then the policy would not run. While trying to get all the Macs in to a managed state I've come across a problem: some of the Macs refuse to be classed as managed when added in via Recon. There are no network issues and Recon reports that it has submitted data successfully but they are still listed as unmanaged.
Has anybody come across this problem and solved it? Using the jamf utility in Terminal didn't solve the problem either.
Thanks,
James
-- James Nairn mailto:jwrn3 at cam.ac.uk
Macintosh Systems Specialist University of Cambridge Computing Service
Pembroke St, Cambridge, CB2 3QH Tel (01223 7)63486
