Leveraging Microsoft AutoUpdate 3.18 "msupdate" binary with Jamf Pro 10 Patch Policies
  • April 26, 2018
  • 55 replies
  • 309 views
dan-snelson
Forum|alt.badge.img+30
While we're waiting for Patch Management to support scripts, here's one method to leverage Microsoft AutoUpdate (MAU) version 3.18 msupdate command-line tool to update Office apps via Jamf Pro 10's built-in patch features, inspired by @pbowden.
Also available on GitHub.
Background
After testing @pbowden's MSUpdateHelper4JamfPro.sh script in our environment, my first thought was to use a payload-free package's post-install script to simply call a policy which ran Paul's script:
Microsoft Office 2016 Update 1.0.0.pkg
Post-install Script
## postinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
echo " "
echo "###"
echo "# Microsoft Office 2016 Update"
echo "###"
echo " "
/usr/local/bin/jamf policy -trigger microsoftUpdate -verbose
After counseling with @ted.johnsen, he convinced me that a Patch Policy calling a standard policy was too much of a hack.
Payload-free Post-install Script
Using Composer, create a payload-free package which contains the following post-install script. (In Composer, I named the package Microsoft Office 2016 msupdate.)
The post-install script will use the word after "Microsoft" in the pathToPackage variable as the application name to be updated (i.e., "Excel") and the word after "msupdate" in the pathToPackage variable as the target version number (i.e., "16.12.18041000").
In Composer, build the .PKG and in the Finder, manually duplicate and rename it based on the application to update and the desired version.
For example:
• Microsoft Word 2016 msupdate 16.12.18041000.pkg
• Microsoft Excel 2016 msupdate 16.12.18041000.pkg
• Microsoft PowerPoint 2016 msupdate 16.12.18041000.pkg
• Microsoft Outlook 2016 msupdate 16.12.18041000.pkg
• Microsoft OneNote 2016 msupdate 16.12.18041000.pkg
Add the packages to the definitions of the Microsoft Office Patch Management Software Titles.
When the patch policies run, the post-install script will leverage the "msupdate" binary to apply the updates.
Updated patch definitions are available on GitHub.
Script
## postinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
# ABOUT
#   Microsoft Office 2016 msupdate Post-install
#   Inspired by: https://github.com/pbowden-msft/msupdatehelper
#   Microsoft AutoUpdate (MAU) version 3.18 and later includes the "msupdate" binary which can be
#   used to start the Office for Mac update process.
#   See: https://docs.microsoft.com/en-us/DeployOffice/mac/update-office-for-mac-using-msupdate
#   Jamf Pro 10 Patch Management Software Titles currently require a .PKG to apply updates
#   (as opposed to a scripted solution.)
#   This script is intended to be used as a post-install script for a payload-free package.
#   Required naming convention: "Microsoft Excel 2016 msupdate 16.12.18041000.pkg"
#   • The word after "Microsoft" in the pathToPackage is the application name to be updated (i.e., "Excel").
#   • The word after "msupdate" in the pathToPackage is the target version number (i.e., "16.12.18041000").
# HISTORY
#     Version 1.0.0, 26-Apr-2018, Dan K. Snelson
#     Version 1.0.1, 21-Jun-2018, Dan K. Snelson
#         Updated PerformUpdate function; thanks qharouff
#         Recorded the version of msupdate installed
echo " "
echo "###"
echo "# Microsoft Office 2016 msupdate Post-install"
echo "###"
echo " "
# Variables
# IT Admin constants for application path
PATH_WORD="/Applications/Microsoft Word.app"
PATH_EXCEL="/Applications/Microsoft Excel.app"
PATH_POWERPOINT="/Applications/Microsoft PowerPoint.app"
PATH_OUTLOOK="/Applications/Microsoft Outlook.app"
PATH_ONENOTE="/Applications/Microsoft OneNote.app"
# Path to package
echo "• pathToPackage: ${1}"
# Target app (i.e., the word after "Microsoft" in the pathToPackage)
targetApp=$( /bin/echo ${1} | /usr/bin/awk '{for (i=1; i<=NF; i++) if ($i~/Microsoft/) print $(i+1)}' )
# Target version (i.e., the word after "msupdate" in the pathToPackage)
targetVersion=$( /bin/echo ${1} | /usr/bin/awk '{for (i=1; i<=NF; i++) if ($i~/msupdate/) print $(i+1)}' | /usr/bin/sed 's/.pkg//' )
echo " "
# Define functions
# Function to check whether MAU 3.18 or later command-line updates are available
function CheckMAUInstall() {
    if [ ! -e "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/msupdate" ]; then
        echo "*** Error: MAU 3.18 or later is required! ***"
        exit 1
    mauVersion=$( /usr/bin/defaults read "/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/Info.plist" CFBundleVersion )
    echo "• MAU ${mauVersion} installed; proceeding ..."
# Function to check whether Office apps are installed
function CheckAppInstall() {
    if [ ! -e "/Applications/Microsoft ${1}.app" ]; then
        echo "*** Error: Microsoft ${1} is not installed; exiting ***"
        exit 1
            echo "• Microsoft ${1} installed; proceeding ..."
# Function to determine the logged-in state of the Mac
function DetermineLoginState() {
    CONSOLE=$( stat -f%Su /dev/console )
    if [[ "${CONSOLE}" == "root" ]] ; then
    echo "• No user logged in"
        CMD_PREFIX=""
    echo "• User ${CONSOLE} is logged in"
    CMD_PREFIX="sudo -u ${CONSOLE} "
# Function to register an application with MAU
function RegisterApp() {
    echo "• Register App: Params - $1 $2"
    $(${CMD_PREFIX}defaults write com.microsoft.autoupdate2 Applications -dict-add "$1" "{ 'Application ID' = '$2'; LCID = 1033 ; }")
# Function to call 'msupdate' and update the target application
function PerformUpdate() {
    echo "• Perform Update: ${CMD_PREFIX}./msupdate --install --apps $1 --version $2 --wait 600 2>/dev/null"
    result=$( ${CMD_PREFIX}/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/msupdate --install --apps $1 $2 --wait 600 2>/dev/null )
    echo "• ${result}"
# Command
CheckMAUInstall
CheckAppInstall ${targetApp}
DetermineLoginState
echo " "
echo "• Updating Microsoft ${targetApp} to version ${targetVersion} ..."
case "${targetApp}" in
 "Word" )
         RegisterApp "${PATH_WORD}" "MSWD15"
         PerformUpdate "MSWD15" "${targetVersion}"
 "Excel" )
         RegisterApp "${PATH_EXCEL}" "XCEL15"
         PerformUpdate "XCEL15" "${targetVersion}"
  "PowerPoint" )
         RegisterApp "${PATH_POWERPOINT}" "PPT315"
         PerformUpdate "PPT315" "${targetVersion}"
  "Outlook" )
         RegisterApp "${PATH_OUTLOOK}" "OPIM15"
         PerformUpdate "OPIM15" "${targetVersion}"
   "OneNote" )
         RegisterApp "${PATH_ONENOTE}" "ONMC15"
         PerformUpdate "ONMC15" "${targetVersion}"
         echo "*** Error: Did not recognize the target appliction of ${targetApp}; exiting. ***"
         exit 1
esac
echo "• Update inventory ..."
/usr/local/bin/jamf recon
echo " "
echo "Microsoft Office 2016 msupdate Post-install Completed"
echo "#####################################################"
echo " "
exit 0      ## Success
exit 1      ## Failure
  • April 27, 2018
I was able to get this to work as a Self Service policy.
Here is my workflow...
  1. Create a package in Composer that holds the script above and the empty named packages. OFFICEUPDATES.pkg
    This package deploys the main script office2016update.sh and packages to the User/Shared folder.
  2. Add this script to JAMF msupdate.sh
    /Users/Shared/office2016update.sh "/Users/Shared/Microsoft Word 2016 msupdate 16.12.18041000.pkg" "/" "/dev/disk1"
    /Users/Shared/office2016update.sh "/Users/Shared/Microsoft Excel 2016 msupdate 16.12.18041000.pkg" "/" "/dev/disk1"
    /Users/Shared/office2016update.sh "/Users/Shared/Microsoft OneNote 2016 msupdate 16.12.18041000.pkg" "/" "/dev/disk1"
    /Users/Shared/office2016update.sh "/Users/Shared/Microsoft PowerPoint 2016 msupdate 16.12.18041000.pkg" "/" "/dev/disk1"
    /Users/Shared/office2016update.sh "/Users/Shared/Microsoft Outlook 2016 msupdate 16.12.18041000.pkg" "/" "/dev/disk1"
  3. Create a Self Service Policy that deploys OFFICEUPDATES.pkg and runs msupdate.sh
  4. My users can now update to the latest version of Office through Self Service or I can manually push the update.
I'm not sure if I'm implementing this in the correct manor but it seems to work.
Thanks Dan
  • April 27, 2018
@dan.snelson
Pardon my ignorance as we just recently upgraded to Jamf Pro 10 and I haven't worked with the Patch Policies much yet but what advantage does all of this have over simply creating a regular policy that can run Paul's script? Throw in a config profile to register the applications and it feels like that would be a whole lot less time and work. Don't get me wrong. Your script looks impressive but needing to name packages each time feels like an awkward step which could simply down to the differences in our environment and/or workflow.
Am I missing something? Part of this might stem from I'm still trying to wrap my head around what the advantages of the Patch Policies are over what I've been doing with policies and smart groups.
dan-snelson
  • April 27, 2018
@jhuls Thanks for your feedback.
For me, one of the primary advantages of using Patch Policies is that "Targets added to the scope are automatically limited to eligible computers" which means fewer Licensed Software Records and Smart Groups to (1) determine if a computer has an application (2) and if its the latest version.
Currently, Patch Policies only allow packages as the means to upgrade an endpoint to the target version.
Yes, I'm manually naming packages, but I'm also no longer storing 4+ GB of Office patches on my Distribution Points for each revision of Office and then requiring the clients to download the 4+ GB of Office patches.
Clear as mud?
  • April 27, 2018
It's all good. It sounds, like I suspected, in that it's a bit about workflow and environment. I've been using smart groups in a way that handled not just patching but installation. I won't claim it's the best solution but it worked pretty well and was simple. I like to see and learn what others are doing though to see if there's a better way whether it's totally switching over and borrowing parts. Probably one of the worst things about my method is that it makes the database grow a bit but I've not heard about how much the patch policies affect the database either to compare to.
Either way I'll certainly test what you've done and evaluate it against things. Thanks for sharing your solution.
  • May 21, 2018
@dan.snelson
I am testing this script and I am noticing that when I install it from Self Service it takes a very long time to run. The logs show it is completed then the next time I open Self Service it still shows the update available. I update it again and it finishes very quickly and logs the update as completed with Jamf.
dan-snelson
  • May 21, 2018
@kbingham Thanks for the feedback.
For any use other than a payload-free, post-install package script used with Patch Policies, you'll probably have better luck with Paul's original MSUpdateHelper4JamfPro.sh script.
  • May 21, 2018
@dan.snelson That is how I am running it within the patch management section. It looks like it runs but has the issues as described above.
dan-snelson
  • May 21, 2018
Thanks for the clarification, @kbingham. Does enabling debug on @pbowden's script reveal any smoking guns?
Also, have you tried modifying the wait value?
  • May 21, 2018
@dan.snelson I will see what I can find out with debugging on @pbowden's script.
I have not messed with the wait value yet but was curious if that would solve the issues.
  • May 21, 2018
I changed the wait to 60 and it has been completing on the first run now.
  • May 22, 2018
Nice post @dan.snelson. Since I dont like spaces in my packages... I modified the 2 variables for extracting app name and target version with
awk -F'_'
preceding the for loop. Of course the packagenames will have underscores replacing all spaces.
dan-snelson
  • May 23, 2018
Patch definitions which don't require Office apps to quit — so msupdate can perform its background update magic — are now available at @brysontyrrell's Community Patch.
BrysonTyrrell
Forum|alt.badge.img+19
  • May 23, 2018
@dan.snelson - still beta! Not recommended for use in prod. The version you're displaying is going to be heavily changed in the near future.
dan-snelson
  • May 23, 2018
Thanks for the heads-up, @brysontyrrell.
What's your official recommendation about using Patch Server for Jamf Pro 0.8.1 on-prem in production?
BrysonTyrrell
  • May 23, 2018
The on-prem project is good to go.
I'm still accepting feedback and adding features to it. In my mind, none of those changes has warranted rolling the version over to a "1.0" yet.
dan-snelson
  • May 23, 2018
@brysontyrrell: I knew I liked you.
Thanks for all your hard work.
BrysonTyrrell
  • May 23, 2018
To those tuning in, be sure to join the discussion and participate in shaping of both these projects on the MacAdmins Slack:
CommunityPatch: #communitypatch https://macadmins.slack.com/messages/C9Z5YUN5N
PatchServer: #patchserver https://macadmins.slack.com/messages/C9RQZ7R7H
qharouff
  • June 21, 2018
The PerformUpdate function should include the --version flag before the '$2' variable if you are wanting to target a specific version for installation.
    result=$( ${CMD_PREFIX}/Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/msupdate --install --apps $1 --version $2 --wait 600 2>/dev/null )
    echo "• ${result}"
dan-snelson
  • June 21, 2018
Excellent catch, @qharouff; I've updated the PerformUpdate function in the original post.
dan-snelson
  • July 1, 2018
  • July 16, 2018
Thanks for this @dan.snelson! One thing I've been trying to figure out is how to get the patch policy to run again if the user decides to "Update Later". Since the patch policy shows as "Completed" but the computer remains in the scope of the policy, I can't seem to get the patch policy to run again via the "jamf patch" command. Maybe there is some kind of timer that needs to run out before it will trigger itself again?
dan-snelson
  • July 16, 2018
@andymcp Version 1.0.5 includes a wait variable (line 58) before performing a recon which has helped some.
We update inventory daily and our non-testers are patched automatically, so they should be automagically properly scoped.
At what frequency are you updating inventory?
Is the Distribution Method for your patch policies set to "Automatically" or "Self Service" ?
  • July 16, 2018
Thanks @dan.snelson Looks like I still had an older version of your script. 1.0.5 seems to have done the trick! I'm guessing it might be the wait before the recon.
I run a recon daily and I'm trying the "Automatically" option for patch policies. My goal was to have it repeatedly annoy the user until they finally click the "Restart App" button and I think this will do nicely.
Thanks for taking the time to put this together along with the msupdate patch definitions!
dan-snelson
  • July 16, 2018
Glad its working, @andymcp.
  • September 11, 2018
Is anyone running into an issue with this not running on machines that are not logged in? I run several computer labs and want to leverage this for them. It is not working properly when logged out.
