Does anyone know of a way to allow non-admin users to grant exceptions to the application firewall without entirely opening up the Security preference pane to them? Basically when the OS prompts "Do you want to allow [application] to accept incoming connections", I want my standard users to be able to allow it. By default this requires admin credentials. I don't want them to be able to disable the firewall or access anything else that is by default locked in the Security preference pane.
Thanks,
Eric
