MACOS MOJAVE download only a redirected file
  • September 24, 2018
  • 15 replies
  • 69 views
MacOS MOJAVE is supposed to be 5.7GB at this time it download only a 22.5 MB file that try to connect to APPLE recovery servers.
does anyone know how to avoid it? i must download a full installer to create our images and update our distribution point.
Best answer by tak10
Run this command and try to download again. It works for me every time.
sudo softwareupdate --clear-catalog
roiegat
Mine installed the 6.5 gig installer.
https://itunes.apple.com/us/app/macos-mojave/id1398502828?ls=1&mt=12
ThijsX
Forum|alt.badge.img+20
  • Employee
@MACHOUSTON Hi
Check this one out to download full installers on a proper way!
https://github.com/munki/macadmin-scripts/blob/master/installinstallmacos.py
the link https://itunes.apple.com/us/app/macos-mojave/id1398502828?ls=1&mt=12 give me the same result it launch ITUNES and only download the 22.5MB file.
i will try later when the server may be less busy.
@MACHOUSTON In case your situation is the same as mine: I didn't get the full installer from the App Store until I updated the Branch of my Software Update Server. I use locally hosted Jamf's NetSUS Software Update Server and hadn't added any new releases today. The App Store still saw the option to download, but just the small version like you did. Once I added today's release to the Branch I'm pointed at it allowed me to download the full installer from the App Store.
  • September 25, 2018
i just tried this morning and yes it worked.
  • October 31, 2018
Doesn't work for the 10.14.1 FULL app.
  • November 1, 2018
@c.archibald
Me too,I can't download the full app.....I have tried all my tricks, going to try one more thing tomorrow and then open a ticket with Apple... : )
C
  • November 1, 2018
I had no luck downloading the full 10.14.1 install app from up-to-date 10.14.1, 10.14.0, 10.13.6, or 10.12.6. I also tried softwareupdate --clear-catalog without luck. Ultimately, I used Greg's handy installinstallmacos.py script to build a 10.14.1 18B75 install app, but System Image Utility would not recognize it as a NetInstall source. I created a 10.14.1 USB installer, did a clean install from USB, then downloaded the full 10.14.1 install app. In other words, I got the stub download on 10.14.1 updated from 10.14.0, but I got the full download from 10.14.1 not updated from 10.14.0. By the way, I initiated the download from the 10.14 App Store app, but it was handed off to the Software Update preference pane.
  • November 5, 2018
I only did it once as I was leaving for the weekend and didn't get to see if it was 10.14.1. or 10.14.0. When I downloaded the mojave installer on a machine that had 10.14.1. all ready installed it did download a full installer...
C
  • November 6, 2018
I used this process to download a full size installer http://osxdaily.com/2018/09/29/download-full-macos-mojave-installer/
  • November 6, 2018
I can confirm that if you download the installer on a machine that has 14.1 installed you will get the full installer...
C
  • November 6, 2018
Also verified that downloading on a 10.14.0 system works.
  • November 6, 2018
@c.archibald on all of my 10.14.0 system I only received the redirected file/fake installer.
C
  • November 7, 2018
@gachowski move of downloading the installer from a 10.14.1 Mac worked. I now have a full 6gb installer for Mojave 10.14.1
