How can I update the password on a local account.
in our case we have "localuser", I see there's a place to edit/change the password, but when I edit/change the password and run the policy I get an error, because it tries to create the account.
what I want is to change the password only for the "localuser"...is there an easy way to do that?
nevermind =( I found it
under Action-> select "Reset Account Password"
thank you Jamf =)
