Unable to use the unix command in ARD to log in as one user on multiple computers running Mojave
  • February 22, 2019
  • 10 replies
  • 64 views
I normally run this script when trying to log into multiple computers via Apple Remote Desktop:
osascript -e 'tell application "System Events"' -e 'keystroke "username"' -e 'keystroke tab'
-e 'delay 0.5' -e 'keystroke "password"' -e 'delay 0.5' -e 'keystroke return' -e 'keystroke return' -e 'keystroke return' -e 'keystroke return' -e 'end tell'
When I try to run this script on computers running Mojave I get the error:
execution error: System Events got an error: osascript is not allowed to send keystrokes. (1002)
Forum|alt.badge.img+15
  • February 22, 2019
The Mac receiving the commands probably needs a PPPC profile that whitelists osascript to control System Events via AppleEvents, and accessibility (for the keystroke).
https://www.jamf.com/jamf-nation/articles/553/preparing-your-organization-for-user-data-protections-on-macos-10-14
  • February 22, 2019
That might work, but I thought Mojave dropped support for running scripts like these at the login window.
  • June 25, 2019
I got this to work in Mojave by using a PPPC config profile for ARDAgent.
  • July 7, 2020
Thanks @zinkotheclown you have no idea how much time you just saved me and my team!
rcole
  • August 11, 2021
Has anyone been able to get this to work during the log in screen in Big Sur?
  • August 24, 2021
+This! Any fix for Big Sur?
  • December 8, 2021
Yes I manage to get it working by doing the following
1. If you have a Restrictions Config Profile make sure Allow AirPlay, View Screen by Classroom, and Screen Sharing (macOS 10.14.4 or later, enrolled via a PreStage enrolment) is checked under the Functionality tab.
2. Create a PPPC
ARD Agent can be found in /System/Library/CoreServices/RemoteManagement/ARDAgent.app >Allow System Events and Accessibility
Script Editor > Allow  Accessibility
rcole
  • September 28, 2022
Anyone able to get this to work using Monterey? If so, are you using a PPC?
The PPPC profile no longer works on newer macOS's starting with Catalina.  You have to enable RDC with a management command in Jamf.
https://community.jamf.com/t5/jamf-pro/enabling-remote-desktop-on-catalina/m-p/224293
FutureFacinLuke
Thank you, this allowed sending Unix commands via ARD
