Deploying AutoCAD 2020 Using Script
  • January 30, 2020
  • 4 replies
  • 45 views
Hi There,
I am using script in the policy to install AutoCAD 2020 to our labs. We are using multiuser license so I am using script to enter the server name on the application.
!/bin/sh
postinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
Silently install Autodesk AutoCAD 2018
SETUP_DIR="/private/etc/Uni/pkg"
INSTALLER_PKG_1="Install Autodesk AutoCAD 2020 for Mac.pkg"
INSTALLER_PKG_2="AutoCAD_Mac_2020.1.2_Hotfix_Combo.pkg"
TEMPLATE_DIR="/System/Library/User Template/English.lproj"
PROD_ID="0000"
SERIAL_ID="00000999"
REG_FILE=
LIC_SERVER="ServerName"
LIC_DIR="/Library/Application Support/Autodesk/AdskLicensingService/777L1_2020.0.0.F"
if [ -f "$SETUP_DIR/$INSTALLER_PKG_1" ]; then cd "$SETUP_DIR" /usr/sbin/installer -allowUntrusted -pkg "$INSTALLER_PKG_1" -target / /usr/sbin/installer -allowUntrusted -pkg "$INSTALLER_PKG_2" -target /
if [ ! -d "$LIC_DIR" ]; then mkdir -p "$LIC_DIR" if [ $? -ne 0 ]; then echo "ERROR: Create directory failed ... "$LIC_DIR exit 254 fi fi cd "$LIC_DIR" echo "_NETWORK" > LGS.data chmod 777 LGS.data echo "done" > nw.cfg # # Write the license file printf "SERVER $LIC_SERVER 0 USE_SERVER " > licpath.lic
# Copy preference files into system user template directory cd "$SETUP_DIR" cp com.autodesk.admigrator2020.plist "$TEMPLATE_DIR/Library/Preferences" cp com.autodesk.adsklicensingagent.plist "$TEMPLATE_DIR/Library/Preferences" cp com.autodesk.adsso-v2.AdSSO-v2.plist "$TEMPLATE_DIR/Library/Preferences" cp com.autodesk.AutoCAD2020.plist "$TEMPLATE_DIR/Library/Preferences"
else echo "ERROR: Installer not found ... $SETUP_DIR/$INSTALLER_PKG_1"
exit 0 ## Success
exit 1 ## Failure
Also I have plist in /Library/LaunchAgent that copies preferences files to users :
<plist version="1.0">
<dict> <key>Label</key> <string>user.script.AutoCADrunatload</string> <key>Program</key> <string>/private/etc/Uni/pkg/AutoCADPlist2020.sh</string> <key>RunAtLoad</key> <true/> <key>StandardOutPath</key> <string>/tmp/AutoCAD.out</string>
</dict>
</plist>
My problem is AutoCAD installs fine and when the first user login to the computer, following window appears and as soon as user clicks on Muti-User window closes and AutoCAD launches. But when next user logs in to the same computer that window doesn't appears any more and application launches no problems.
appreciate any help I get. thank you in advance.
Lincolnep
  • March 18, 2020
Hi @raghdasi I have the install and the licencing working for AutoCAD 2020 but have been unable to get the hotfix to install.
Here is the postinstall script that I am using to get it to install and licence without the popup on first run you are having:
# Install AutoCAD 2020
installer -pkg "Install Autodesk AutoCAD 2020 for Mac.pkg" -target /
# Licence AutoCAD 2020
/Library/Application Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper change --prod_key 777L1 --prod_ver 2020.0.0.F --lic_method "NETWORK" --lic_server_type "SINGLE" --lic_servers "serverURL"
if you run:
/Library/Application Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper h
you will be able to see the options you have for getting Autodesk products to licences on mac's
I will be giving your way of installing the hotfix a go as i have tried using JamF and by script but not with the -allowUntrusted option in my script.
So far this has also worked for Autodesk Mudbox 2020 as well.
  • March 18, 2020
Thanks @Lincolnep. Will try this.
Lincolnep
  • March 18, 2020
@raghdasi after a bit of work I managed to get the hotfix to install as well here is my working script:
# Setup for installing Hotfix Combo
# Open Hotfix Combo up in Suspicious Package https://www.mothersruin.com/software/SuspiciousPackage/
# Look for VerTarget.plist in pkg locate the UpdateVersion and copy that to the bellow var
UpdateVersion="23.1.46.205"
# Make sure it is clean.
if [ -d /private/tmp/_adsk_${UpdateVersion} ]; then
    rm -R /private/tmp/_adsk_${UpdateVersion}
mkdir -p /private/tmp/_adsk_${UpdateVersion}
ln -s /Applications/Autodesk/AutoCAD 2020/AutoCAD 2020.app /private/tmp/_adsk_${UpdateVersion}/acupdt_rone
# Install Hotfix Combo
/usr/sbin/installer -allowUntrusted -verboseR -pkg "AutoCAD_Mac_2020.1.2_Hotfix_Combo.pkg" -target /
  • May 18, 2020
Thanks for this! I was looking for this exact answer.
