Mavericks Dropping Network connection on test Mac Mini server
  • January 29, 2014
  • 104 replies
  • 474 views
Hi JamfNation.
I am working on setting up a Casper 9.22 test server. Mid 2012 Mac Mini, 10.9.1, Server app 3.0.2. I have been round and round with my networking team and for some unknown reason my ethernet connection keeps dropping every 15-20 minutes. I've rebuilt the server from scratch once but the issue still exists. I made sure all of my energy saver settings were setup to never and even went as far as making ethernet the only network interface. I ruled out it being a hardware issue by hooking up a new Macbook pro with 10.9.1 to my port and it even dropped the connection. I check Apple forums and a lot of people seem to be having issues with Mavericks and staying connected. I was just curious is anyone else out there have run into any issues like this.
bentoms
Forum|alt.badge.img+35
  • January 29, 2014
I have 11 Mac Mini servers globally deployed & none have this issue.
Neither do my 10.9 clients.
Does sound a bit like an issue with that port/switch.
  • January 29, 2014
Thanks bentoms. Sadly, my internal network admins refuse to believe it's a networking side issue since a PC plugged into the same port with the same static IP and DNS name doesn't have a problem. Oh the woes of being a Mac admin is a windows world.
  • January 29, 2014
Can't say I've seen this issue but the only other thing that comes to mind is to check that the network service order sets your wired connection to the highest ordered connection. For some stupid reason, Apple sets Bluetooth DUN highest.
You can check this with
/usr/sbin/networksetup -listnetworkserviceorder
and set with
sudo /usr/sbin/networksetup -ordernetworkservices <service1> <service2> <service3> <...>
or from the main Network SysPref pane (the gear on the lower left side)
Good luck and hope this helps
dlondon
  • January 30, 2014
As it's a test machine, can't you plug it in somewhere else to see if it works anywhere? If it does work then you have your evidence of some weird interaction with that particular switch. However if it still acts up you can send it back to Apple :)
Mauricio11
  • January 30, 2014
We have found network issues from our Macs that were upgraded to 10.9.
There is a new security feature in Mavericks, 'ARP Validation'.
The blog from Citrix explaining it in more details.
http://blogs.citrix.com/2013/10/31/citrix-on-osx-10-9-mavericks/
Hope this can help you.
Regards
Mauricio
  • January 30, 2014
Thanks everyone for the replies. I changed the service order and I confirmed it was fine plugged in elsewhere. The article Mauricio linked me is almost identical to my issue, a Mac mini running 10.9 plugged into a Cisco core and it's dropping connection. I will try the fix in the article and reply if it fixes it. Thanks again fellow Jamf Nation members for the help!!!!
  • January 30, 2014
Unfortunately disabling the ARP didn't help my issue. Off to the Apple Store I go.
  • January 30, 2014
hi
im having the same issue on mac pro server 10.9.1...
AND now on my other mac mini server that i just upgraded to 10.9.1...
none of my other 10.8 or 10.7 server doing that... looks really problem with 10.9.1 !!!
  • April 1, 2014
I just started seeing this late last week on my 10.9 Mac mini server. It had been running fine for weeks and just started up. I see network disconnect errors in the logs and have noticed that user sessions aren't getting disconnected when it happens (they hang around in the Connected Users tab). Threads on Apple support discussions about it too. Upgraded to 10.9.2 and no change.
  • April 7, 2014
I had to put my Mac mini server back on 10.8.5 for now. I setup a NetBoot/SUS appliance to handle managing updates for 10.9 clients. I am waiting for the 10.9.3 GM seed and then crossing my fingers.
  • April 16, 2014
Just wanted to add some more information here:
I'm also seeing this connectivity issue on a Mac Mini Server running 10.9.2, where I'm seeing periodic dropped packets from just standard pinging from the Network Utility. Tried running the script provided by Citrix, and I'm still seeing the same issue. However, I have a feeling this is not just a software issue. I have an Xserve also running 10.9.2 and I'm not seeing any connectivity issues at all, so this might be related to the NIC and or the NIC driver for the Ethernet hardware built into the Mac Mini and or Mac Pro. Both the Xserve and the Mini I tested on are connected directly to Cisco cores.
nick1313
  • April 25, 2014
I am also having this issue with a couple of mac mini servers. I've tried the fixes mentioned in this thread, none have worked.
I have contacted AppleCare support but this issue is too high level for them so I will be contacted enterprise level support as well, as soon as we have an agreement in place.
In the meantime has anyone found anymore information on this? We have HP procurve core switches that the apple servers are plugged into and are on their own vlan (same one as about 150 other servers, various windows/linux, that aren't having this issue). We are also attacking this from an HP switch angle, we have an open case with them in an effort to see if they can find something.
A couple oddities that we have found.
  1. If the servers are statically assigned to our local subnet (not in a vlan) they don't have this issue, which I think might rule out the hardware issue.
  2. The servers still seem to be transmitting data when they drop pings/packets.
We are looking to, potentially, buy a bunch more of these servers to help manage our ipads/macbooks, so hopefully this issue will get resolved.
I will report back anything I get from enterprise support.
Forum|alt.badge.img+15
  • April 25, 2014
Seeing very similar issues with a couple of Mac Minis connected to Cisco 3560X switches running 12.2(53)SE2. I've reproduced the issue on both 10.9.2 and 10.9.3(Build 13D45a) with a current gen Mac Mini as well as a mid 2012 MacBook Pro.
  • April 25, 2014
hi
same here... 2 different machines... mac mini and mac pro... all on 10.9.2. They all work everywhere else on our VLAN but not in this VLAN
everything is pointing out to the version our Cisco switches are running their OS... Its the only place using old version of OS on cisco...
All our other servers running 10.8 and before is working fine...
10.9.3 did not solve the issue for us with beta testing...
  • April 25, 2014
Cisco switches here as well but I'd have to check with our network team on models and software versions. I've been working on another project that will wrap up next week, after that I plan to submit a ticket to AppleCare Enterprise support as well.
  • April 25, 2014
as far as my network team told me... the only place in our huge network we have problems is equipped with OS i think version 12...
all other places is recent version... we might get into upgrading our stack this summer
nick1313
  • April 25, 2014
The 1st level support (applecare) guy I talked to said he never heard of any of this, I even linked him to this thread. Maybe if more people contact them it will become a little higher priority for them, because it's obviously happening to more people.
He basically said there wasn't much he could do, since it was more high level, but also because I was the first person that he heard it from. Also since it's happening on multiple brands of switches/networks/etc it's gotta be something with the new OS.
  • April 25, 2014
I know it has to do with ARP Inspection and redundancy protocols used on managed switches environment....
He can't say he doesn't know... many threads only reports this problem... weird...
nick1313
  • April 25, 2014
Yea, maybe that was just his way of deflecting the issue to enterprise support or maybe at the enterprise level they have a fix but want you to pay for it, I don't know.
I would think if it were a bug in the software, which it definitely seems to be, they should send out an update to fix the issue and not make you pay for enterprise support.
I'll be honest though, I don't know next to nothing about how switches are setup and what ARP Inspection and redundancy protocols are, we have two network guys that do that stuff. However they aren't here today.
  • April 28, 2014
we are also seeing this issue with Cisco gear using Gateway Load Balancing Protocol (with Mavericks clients), this Apple article describes the issue and the script has worked for us so far in a few tests.
Article: https://discussions.apple.com/thread/5483424?start=0&tstart=0
Script: https://github.com/MacMiniVault/Mac-Scripts/tree/master/unicastarp
  • April 28, 2014
Tried this patch multiple times and multiple systems 10.9.... not working at all for us... very bad situation
nick1313
  • April 30, 2014
I wanted to throw out an update on this and I think taugust04 is on to something. One of our network guys had the bright idea of trying out a usb to ethernet adapter and we haven't had any time outs for the last 2 hours. I'm going to keep monitoring it for the next day.
  • April 30, 2014
Hi
Se tried thunder to ethernet and we had same problems
mpermann
Forum|alt.badge.img+22
  • May 1, 2014
@nick1313, did you use an Apple USB to Ethernet adapter or a third party adapter? If it's a third party adapter, do you mind sharing the specifics of the adapter you are testing?
  • May 1, 2014
hi
same comment here... i tried thunderbolt to ethernet... same problem... do you think usb to ethernet would be different ?
