I just got a PDF from Apple with 50 license codes for Final Cut Pro X to download from the App Store. How exactly am I supposed to deal with this from a package-creation standpoint?? Anyone tried this yet?
Thanks,
-lauren
lauren nicholas
User Support & Technology Analyst – Hurd Campus
Center for Information Technology
Moravian College
610 861 1633
That is, right there, the $64,000 question.
On Jul 5, 2011, at 1:32 PM, Nicholas, Lauren wrote:
--Jim
Apple must have a solution for you, or they wouldn't have put it in the App Store.
If Apple treats it like they do Adobe, you can use the same serial for all seats, just having proof that you've bought all 50. My only concern would be some sort of DRM/copy check to see if there's another seat on the network with the same key. Seems like something that your sales rep should be able to answer.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
Yeah I got same email but couldnt download on my admin composer mac as my graphics card isn't good enough
Criss Myers
You can install on one mac then package it. Then this package can be used for multiple Mac deployments. Make sure you have matching number of licenses.
http://support.apple.com/kb/HT4781
